[postgis-users] How to configure Postgis/Postgresql to use with QGIS
Puneet Kishor
punk.kish at gmail.com
Thu Dec 29 07:57:22 PST 2011
On Dec 29, 2011, at 9:54 AM, Daniel Montenegro wrote:
> Thanks Sindile and Brent,
> Actually, I've unnistalled Postgres (the latest version - 9.xx) and
> downloaded an older one (8.1.4 - I guess). Then I used STACK BUILDER to
> install PostGIS on Postgres.
> Now let me ask you something else:
> Supose that I have a polygon shape - like "MyCyty.shp", how can I export it
> to Postgres *via* Postgis.
shp2pgsql
> I tryed to use the SPIT plugin from QGIS but
> isn't working right yet... Do I have to create some spatial database in
> Postgres before trying to export it in QGIS?
> Thanks a lot!
> Daniel
> P.S.: I'm using PGADMIN.
> 2011/12/29 <pcreso at pcreso.com>
>> Hi Daniel,
>> The docs are a good place to start, but here is the simple version, from
>> the command line...
>> If you have got Postgres installed OK, you need to create a new database,
>> then install Postgis into it, so I'm assuming you have a working Postgres
>> superuser account you can use. Then:
>> # create the new, empty database
>> createdb test_gis
>> # add support for the plpgsql language. Not always needed for v9+ of
>> Postgres, but it # won't hurt anything to try it anyway.
>> createlang test_gis plpgsql
>> # find where on your system the postgis.sql & spatial_reference_sys.sql
>> files are
>> # run these in your new database
>> psql -d test_gis -f postgis.sql
>> psql -d test_gis -f spatial_ref_sys.sql
>> # You now have a working Postgis database.
>> # connect to the database
>> psql -d test_gis
>> # create a simple table there. QGIS likes integer primary keys, this gives
>> it one
>> create table test_tab (id serial primary key, name varchar(12));
>> # add a lat/long geometry column to the table
>> select addgeometry('','test_tab','geom',4326,'POINT',2);
>> # add a couple of points to the table
>> insert into test_tab values (default,'point 1',ST_setsrid(makepoint(179,
>> -45),4326));
>> insert into test_tab values (default,'point 2',ST_setsrid(makepoint(179.2,
>> -45.2),4326));
>> # see that they exist:
>> select * from test_tab;
>> select id, name, ST_astext(geom) as geom from test_tab;
>> # exit postgres
>> \q
>> To open the table & see the points plotted in QGIS you have a bit of
>> configuration to do. By default a Postgres database is installed securely,
>> so external applications & remote computers cannot connect to it.
>> The instructions here open the database up to anyone, so it is pretty
>> insecure. If you want to address this, read the Postgres docs...
>> Shut down your Postgres server. How you do this depends on your operating
>> system & version.
>> find the file "pg_hba.conf". It contains the access settings.
>> edit this (you may need admin rights) & set all users from all IP
>> addresses for all databases to "trust", as described in the file
>> find the file postgresql.conf
>> edit this & set "listen_addresses" to "*" as described in the file ( = all)
>> restart the Postgresql service, it will now have an open access
>> configuration, as you just specified.
>> You can now fire up QGIS on a local or remote system & connect to the
>> database test_gis on the specified server (if same system as the database,
>> the host is called localhost). QGIS will show you the table test_tab &
>> adding this should show your two points.
>> HTH,
>> Brent Wood
>> --- On *Thu, 12/29/11, Daniel Montenegro <dmontenegro84 at gmail.com>* wrote:
>> From: Daniel Montenegro <dmontenegro84 at gmail.com>
>> Subject: [postgis-users] How to configure Postgis/Postgresql to use with
>> QGIS
>> To: postgis-users at postgis.refractions.net
>> Date: Thursday, December 29, 2011, 2:37 PM
>> Hi there!
>> I've installed Postgis but I'm not being able to create a "spatial" table
>> with a geometry column in Postgresql. Actually, I think I still didn't get
>> all the steps to configure postgis in postgresql.
>> I really need some help!
>> Thanks a lot,
>> Daniel
>> -----Inline Attachment Follows-----
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net<http://mc/compose?to=postgis-users@postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
