[postgis-users] defending postgresql - postgis.
Frederik Ramm
frederik at remote.org
Tue Feb 1 15:38:46 PST 2011
Paragon Corporation wrote:
> OpenStreetMap also runs on PostgreSQL now too (had switched from MySQL),
> though I don't think they run on PostGIS.
Correct; details about the server running core OSM database is here:
http://wiki.openstreetmap.org/wiki/Servers/smaug
This server does not even make use of PostgreSQL's two-dimensional
indexes; stores points with integer values for lat/lon and computes a
"bucket" id for each point so that they can be retrieved quickly through
an one-dimensional index. This is a left-over from the time when someone
running the OSM backend would have a choice between using MySQL and
PostgreSQL and nobody saw the need to fix it.
> Of course PostGIS enjoys preferential treatment as far as if you want to
> load OpenStreetMap data into it. I don't think the tools for other
> databases compares.
That is slightly misleading; there are tools to load OSM data into a
PostgreSQL database like the one used on the central server, but there
are *also* tools that will populate a PostGIS table from OSM data,
optimised for rendering. This comes with a loss of parts of the data
(and topology) which are not needed for drawing maps.
Details about the server at OSM HQ that runs the PostGIS database for
map rendering here: http://wiki.openstreetmap.org/wiki/Servers/yevaud
For those really interested, you can even go up one step in the Wiki
hierarchy and access Munin graphs that tell you something about the
database use. If any of you PostgreSQL buffs spot something in there
that looks fishy, let us know ;)
Bye
Frederik
Frederik Ramm ## eMail frederik at remote.org ## N49°00'09" E008°23'33"
