[postgis-users] postgis visual client
Michaël Michaud
michael.michaud at free.fr
Tue Feb 8 16:32:41 PST 2011
Le 08/02/2011 19:21, Paragon Corporation a écrit :
> John,
> We like using OpenJump for that -- here is a quick tutorial we wrote
> up on doing Ad hoc queries with it.
> http://www.postgresonline.com/journal/index.php?/archives/72-OpenJump-for-PostGIS-Spatial-Ad-Hoc-Queries.html
> It works fine with PostgreSQL 9.0, but if you are using 9.0 -- you
> need to download the latest JDBC drivers or set your bytea_output to
> escape - both are documented in the FAQ
> http://www.postgis.org/documentation/manual-svn/PostGIS_FAQ.html#id2686352
Thanks for the good documentation,
Would like to mention an undocumented feature coming with the last
OpenJUMP release.
You can copy the "fence" geometry or the "view extent" in your query :
button View (Vue in the screenshot) will copy "${view:-1}" where ever
you want in the query (replaced by view extent at execution time)
button Fence (Cadre in the screenshot) will copy "${fence:-1}" where
ever you want in the query (replaced by the fence geometry at execution
time)
It may help to download small parts of large datasets.
Michaël
> Leo
> http://www.postgis.us
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *John Callahan
> *Sent:* Tuesday, February 08, 2011 12:25 PM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] postgis visual client
> I'm sure this has been asked many times but haven't found a definitive
> or consensus answer...
> Is there a postgis client that supports spatial, ad hoc queries and
> returns those results to a map? This would include simple (and more
> complex) SELECT statements but also other queries with spatial
> results, such as finding nearest neighbors, intersect, union, etc...
> The best idea I found was to create a view from the ad hoc query and
> then use a desktop GIS to display that view. You'd need to update the
> view (and refresh the GIS screen) to run a new query. I know QGIS
> (and other FOSS GIS packages) allows you to create a definition query
> (a where clause to subset the layer) and does support database views.
> I haven't seen a place where QGIS supports ad hoc queries. Searching
> the web, I did find references to some work done using OpenMap
> libraries back in 2004, and the mezoGIS package from around 2005/2006.
> Does anyone know of a GUI tool to use, hopefully one that works for
> Postgres 9 and PostGIS 2? Thanks.
> - John
> PS - Thanks for the recommendations on the PostGIS in Action book. I
> just purchased it and looking forward to learning what I can.
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110209/83446ec2/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110209/83446ec2/attachment.png>
