[postgis-users] postgis visual client
John Callahan john.callahan at udel.edu
Tue Feb 8 11:10:55 PST 2011
Thanks for the responses.  What you describe in your write up with OpenJump
is exactly what I'm trying to do.  Also, in addition to the QGIS plugins
strk mentions, I just found two more possibilities: PgQuery for QGIS and
Postgis SQL Editor.  Looks like there are some good options available.
Thanks again.
- John
On Tue, Feb 8, 2011 at 1:21 PM, Paragon Corporation <lr at pcorp.us> wrote:
>  John,
> We like using OpenJump for that -- here is a quick tutorial we wrote up on
> doing Ad hoc queries with it.
> http://www.postgresonline.com/journal/index.php?/archives/72-OpenJump-for-PostGIS-Spatial-Ad-Hoc-Queries.html
> It works fine with PostgreSQL 9.0, but if you are using 9.0 -- you need to
> download the latest JDBC drivers or set your bytea_output to escape - both
> are documented in the FAQ
> http://www.postgis.org/documentation/manual-svn/PostGIS_FAQ.html#id2686352
> Leo
> http://www.postgis.us
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *John
> Callahan
> *Sent:* Tuesday, February 08, 2011 12:25 PM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] postgis visual client
> I'm sure this has been asked many times but haven't found a definitive or
> consensus answer...
> Is there a postgis client that supports spatial, ad hoc queries and returns
> those results to a map?  This would include simple (and more complex) SELECT
> statements but also other queries with spatial results, such as finding
> nearest neighbors, intersect, union, etc...
> The best idea I found was to create a view from the ad hoc query and then
> use a desktop GIS to display that view.  You'd need to update the view (and
> refresh the GIS screen) to run a new query.   I know QGIS (and other FOSS
> GIS packages) allows you to create a definition query (a where clause to
> subset the layer) and does support database views.  I haven't seen a place
> where QGIS supports ad hoc queries.  Searching the web, I did find
> references to some work done using OpenMap libraries back in 2004, and the
> mezoGIS package from around 2005/2006.
> Does anyone know of a GUI tool to use, hopefully one that works for
> Postgres 9 and PostGIS 2?  Thanks.
> - John
> PS - Thanks for the recommendations on the PostGIS in Action book.  I just
> purchased it and looking forward to learning what I can.
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110208/22e28a61/attachment.html>
