[postgis-users] postgis visual client
David Fawcett
david.fawcett at gmail.com
Tue Feb 8 11:02:17 PST 2011
If you are looking for a Web-based solution, MapServer should do this as well.
David.
On Tue, Feb 8, 2011 at 12:21 PM, Paragon Corporation <lr at pcorp.us> wrote:
> John,
> We like using OpenJump for that -- here is a quick tutorial we wrote up on
> doing Ad hoc queries with it.
> http://www.postgresonline.com/journal/index.php?/archives/72-OpenJump-for-PostGIS-Spatial-Ad-Hoc-Queries.html
> It works fine with PostgreSQL 9.0, but if you are using 9.0 -- you need to
> download the latest JDBC drivers or set your bytea_output to escape - both
> are documented in the FAQ
> http://www.postgis.org/documentation/manual-svn/PostGIS_FAQ.html#id2686352
> Leo
> http://www.postgis.us
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of John
> Callahan
> Sent: Tuesday, February 08, 2011 12:25 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] postgis visual client
> I'm sure this has been asked many times but haven't found a definitive or
> consensus answer...
> Is there a postgis client that supports spatial, ad hoc queries and returns
> those results to a map? This would include simple (and more complex) SELECT
> statements but also other queries with spatial results, such as finding
> nearest neighbors, intersect, union, etc...
> The best idea I found was to create a view from the ad hoc query and then
> use a desktop GIS to display that view. You'd need to update the view (and
> refresh the GIS screen) to run a new query. I know QGIS (and other FOSS
> GIS packages) allows you to create a definition query (a where clause to
> subset the layer) and does support database views. I haven't seen a place
> where QGIS supports ad hoc queries. Searching the web, I did find
> references to some work done using OpenMap libraries back in 2004, and the
> mezoGIS package from around 2005/2006.
> Does anyone know of a GUI tool to use, hopefully one that works for Postgres
> 9 and PostGIS 2? Thanks.
> - John
> PS - Thanks for the recommendations on the PostGIS in Action book. I just
> purchased it and looking forward to learning what I can.
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> postgis-users mailing list
