[postgis-users] postgis visual client
j.rolland
jrmrolland at aol.com
Thu Feb 10 01:51:58 PST 2011
John,
I developed a plugin for PgAdmin III to visualize PostGIS data.
Go to the following link
http://ageoguy.blogspot.com/2010/06/plugin-pgadmin-iii-postgisviewer-suite.html
postgisviewer a plugin for PgAdmin III
on my blog where you can download it and you will find a tutorial (in
french) to install and use it.
You can also consult this link
http://www.postgresonline.com/journal/archives/180-pgAdmin113plugins_postgis.html
Postgresonline journal pgAdmin III plugins postgis
Regards,
Jérôme Rolland
John Callahan wrote:
> I'm sure this has been asked many times but haven't found a definitive or
> consensus answer...
> Is there a postgis client that supports spatial, ad hoc queries and
> returns
> those results to a map? This would include simple (and more complex)
> SELECT
> statements but also other queries with spatial results, such as finding
> nearest neighbors, intersect, union, etc...
> The best idea I found was to create a view from the ad hoc query and then
> use a desktop GIS to display that view. You'd need to update the view
> (and
> refresh the GIS screen) to run a new query. I know QGIS (and other FOSS
> GIS packages) allows you to create a definition query (a where clause to
> subset the layer) and does support database views. I haven't seen a place
> where QGIS supports ad hoc queries. Searching the web, I did find
> references to some work done using OpenMap libraries back in 2004, and the
> mezoGIS package from around 2005/2006.
> Does anyone know of a GUI tool to use, hopefully one that works for
> Postgres
> 9 and PostGIS 2? Thanks.
> - John
> PS - Thanks for the recommendations on the PostGIS in Action book. I just
> purchased it and looking forward to learning what I can.
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> postgis-users mailing list
View this message in context: http://old.nabble.com/postgis-visual-client-tp30875438p30890812.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
