[postgis-users] Error in raster import with WKTRaster
Mathieu Basille basille at ase-research.org
Mon Feb 14 11:19:27 PST 2011
Dear Jorge,
Seems to work for me. I'm not sure if I did it correctly, here is what I
did:
1) download the raster2pgsql.py file at
http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/python/raster2pgsql.py?rev=6815
2) place it in /usr/lib/postgresql/8.4/bin/ for convenience (this is
where shp2pgsql lives) and create a link in /usr/bin/
3) convert my GeoTiff again:
raster2pgsql -r RoadDensity_2002_2006_CV_UTM19_25m.tif -t
roaddensity_2002_2006_cv_utm19_25m -s 26919 -k 50x50 -I >
RoadDensity_2002_2006_CV_UTM19_25m.sql
I noticed that I had to use the -t option now (it was absent in my
gdal2raster.py loader).
4) load it in the DB as usual, using the postgres user:
psql -f RoadDensity_2002_2006_CV_UTM19_25m.sql geodb
And it proceeded without any error or warnings. I haven't tested it
thoroughly though, but it seems to work fine now!
Thanks a lot for the correction!
Mathieu.
Le 2011-02-14 07:20, Jorge Arévalo a écrit :
> 2011/2/14 Jorge Arévalo <jorge.arevalo at deimos-space.com>:
>> 2011/2/12 Mathieu Basille <basille at ase-research.org>:
>>> Dear Jorge,
>>> Thx for this. Shall I do anything about it? I uploaded the problematic
>>> raster for Pierre here:
>>> http://ase-research.org/tmp/postgis/
>>> Pierre, are you working on this?
>>> Sorry if I'm a bit confused, I'm not quite sure what's the best to do as I'm
>>> not familiar with the PostGIS Raster organisation...
>>> And I don't want to add more work for the people involved in PostGIS Raster
>>> than required.
>>> All the best,
>>> Mathieu.
>> Hi Mathieu,
>> I think is enough. The loader should know how to deal with that.
>> About PostGIS Raster, basically there's a roadmap
>> (http://trac.osgeo.org/postgis/wiki/WKTRaster/PlanningAndFunding) and
>> a list of known bugs and new required features
>> (http://trac.osgeo.org/postgis/report/17).
>> So, if you found a new problem (like your case) or a lack of
>> something, you can use the list to ask for it, and a new ticket will
>> be created when needed (like your case, again).
>> Apart from this, the only thing you need is patience :-)
>> Thanks again for reporting this, and best regards,
>> Jorge Arévalo
>> Internet & Mobilty Division, DEIMOS
>> http://es.linkedin.com/in/jorgearevalo80
>> http://mobility.grupodeimos.com/
>> http://gis4free.wordpress.com
>> http://geohash.org/ezjqgrgzz0g
> Hello again,
> I think the loader problem is solved in r6815. Mathieu, could you
> please update your working copy of PostGIS? You don't need to rebuild.
> Just execute the loader again, and test the generated SQL, please.
> Best regards,
~$ whoami
Mathieu Basille, Post-Doc
~$ locate
Laboratoire d'Écologie Comportementale et de Conservation de la Faune
+ Centre d'Étude de la Forêt
Département de Biologie
Université Laval, Québec
~$ info
http://ase-research.org/basille
~$ fortune
``If you can't win by reason, go for volume.''
Calvin, by Bill Watterson.
