[postgis-users] Error in raster import with WKTRaster
Jorge Arévalo jorge.arevalo at deimos-space.com
Tue Feb 15 02:52:35 PST 2011
Hi Mathieu,
2011/2/14 Mathieu Basille <basille at ase-research.org>:
> Dear Jorge,
> Seems to work for me. I'm not sure if I did it correctly, here is what I
> did:
> 1) download the raster2pgsql.py file at
> http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/python/raster2pgsql.py?rev=6815
> 2) place it in /usr/lib/postgresql/8.4/bin/ for convenience (this is
> where shp2pgsql lives) and create a link in /usr/bin/
> 3) convert my GeoTiff again:
> raster2pgsql -r RoadDensity_2002_2006_CV_UTM19_25m.tif -t
> roaddensity_2002_2006_cv_utm19_25m -s 26919 -k 50x50 -I >
> RoadDensity_2002_2006_CV_UTM19_25m.sql
> I noticed that I had to use the -t option now (it was absent in my
> gdal2raster.py loader).
> 4) load it in the DB as usual, using the postgres user:
> psql -f RoadDensity_2002_2006_CV_UTM19_25m.sql geodb
> And it proceeded without any error or warnings. I haven't tested it
> thoroughly though, but it seems to work fine now!
> Thanks a lot for the correction!
> Mathieu.
Sounds correct. I'm glad you (apparently) solved the problem with that
change :-).
Best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
> Le 2011-02-14 07:20, Jorge Arévalo a écrit :
>> 2011/2/14 Jorge Arévalo <jorge.arevalo at deimos-space.com>:
>>> 2011/2/12 Mathieu Basille <basille at ase-research.org>:
>>>> Dear Jorge,
>>>> Thx for this. Shall I do anything about it? I uploaded the problematic
>>>> raster for Pierre here:
>>>> http://ase-research.org/tmp/postgis/
>>>> Pierre, are you working on this?
>>>> Sorry if I'm a bit confused, I'm not quite sure what's the best to do as I'm
>>>> not familiar with the PostGIS Raster organisation...
>>>> And I don't want to add more work for the people involved in PostGIS Raster
>>>> than required.
>>>> All the best,
>>>> Mathieu.
>>> Hi Mathieu,
>>> I think is enough. The loader should know how to deal with that.
>>> About PostGIS Raster, basically there's a roadmap
>>> (http://trac.osgeo.org/postgis/wiki/WKTRaster/PlanningAndFunding) and
>>> a list of known bugs and new required features
>>> (http://trac.osgeo.org/postgis/report/17).
>>> So, if you found a new problem (like your case) or a lack of
>>> something, you can use the list to ask for it, and a new ticket will
>>> be created when needed (like your case, again).
>>> Apart from this, the only thing you need is patience :-)
>>> Thanks again for reporting this, and best regards,
>>> Jorge Arévalo
>> Hello again,
>> I think the loader problem is solved in r6815. Mathieu, could you
>> please update your working copy of PostGIS? You don't need to rebuild.
>> Just execute the loader again, and test the generated SQL, please.
>> Best regards,
> ~$ whoami
> Mathieu Basille, Post-Doc
> ~$ locate
> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
> + Centre d'Étude de la Forêt
> Département de Biologie
> Université Laval, Québec
> ~$ info
> http://ase-research.org/basille
> ~$ fortune
> ``If you can't win by reason, go for volume.''
> Calvin, by Bill Watterson.
