[postgis-users] Looking for a points to moving average path function
Stephen Woodbridge woodbri at swoodbridge.com
Wed Feb 23 10:51:34 PST 2011
Hi All,
I have a table of points and I would like to generate a path from these
points.
This works very well for the raw points:
select device, makeline(p) as the_geom from
       (select device, p from gpspoints order by seq) as foo
         group by device;
I would like to smooth these points using a moving average where if the
number of points in the average is say 3 then the points are:
p[1]
(p[1]+p[2])/2
(p[1]+p[2]+p[3])/3
(p[2]+p[3]+p[4])/3
(p[n-2]+p[n-1]+p[n])/3
and these points are then used in makeline().
So I can do a brute force iterative function, but it seems like there
should be a more elegant solution.
Thoughts, code snippets, etc?
I'm working with postgresql 8.3, 8.4 and postgis 1.5 at the moment.
-Steve
