[postgis-users] Looking for a points to moving average path function
Stephen Woodbridge woodbri at swoodbridge.com
Wed Feb 23 13:52:44 PST 2011
So if anyone cares this is what I came up with:
CREATE OR REPLACE FUNCTION movingaveragepoints(num integer, id integer)
   RETURNS SETOF geometry AS
$BODY$
  * num - number of points in the moving average
  * id  - did for the device we want the path for
DECLARE
     i    integer;
     cnt  integer;
     p    record;
BEGIN
     SELECT INTO cnt COUNT(*) FROM gpspoints WHERE did=id;
     -- assumes seq values are in the range 1..n
     FOR i IN 1..cnt LOOP
         SELECT INTO p AVG(lat) as y, AVG(lon) as x FROM
             (SELECT lat, lon FROM gpspoints
               WHERE did=id and seq > i-num and seq <= i) as foo;
         RETURN NEXT setsrid(makepoint(p.x, p.y),4326);
     END LOOP;
     RETURN;
END;
$BODY$
   LANGUAGE plpgsql STABLE
   COST 10;
-- this works great! get results
SELECT asewkt(movingaveragepoints) from movingaveragepoints(5, 1);
-- and so does this
SELECT astext(makeline(p1)) from
   (SELECT movingaveragepoints as p1
      from movingaveragepoints(5, 1)) as foo;
Open to better ideas if anyone has them.
Thanks,
   -Steve
On 2/23/2011 1:51 PM, Stephen Woodbridge wrote:
> Hi All,
> I have a table of points and I would like to generate a path from these
> points.
> This works very well for the raw points:
> select device, makeline(p) as the_geom from
> (select device, p from gpspoints order by seq) as foo
> group by device;
> I would like to smooth these points using a moving average where if the
> number of points in the average is say 3 then the points are:
> p[1]
> (p[1]+p[2])/2
> (p[1]+p[2]+p[3])/3
> (p[2]+p[3]+p[4])/3
> (p[n-2]+p[n-1]+p[n])/3
> and these points are then used in makeline().
> So I can do a brute force iterative function, but it seems like there
> should be a more elegant solution.
> Thoughts, code snippets, etc?
> I'm working with postgresql 8.3, 8.4 and postgis 1.5 at the moment.
> -Steve
> postgis-users mailing list
