[postgis-users] Calculate Average Distance (w/ LIMIT)
Ben Madin
lists at remoteinformation.com.au
Mon Jan 3 18:10:44 PST 2011
Andreas,
I can't improve on Nicolas' suggestion, but at a guess you might also want to look at the spatstat package in R, which has defined a number of functions for this sort of analysis, and can include windows (ie country polygons) to incorporate edge correction - ie F, G and K functions.
cheers
Ben
On 03/01/2011, at 9:05 PM, Nicolas Ribot wrote:
> On 6 December 2010 13:19, Andreas Forø Tollefsen <andreasft at gmail.com> wrote:
>> Hi all.
>> I have two point data sets. One point set is health observations, the other
>> one is conflicts.
>> What i want to do is to calculate the average distance from each health
>> observation to the 10 nearest conflict points.
>> I have managed to calculate the average distance, but only to all conflict
>> points.
>> My query:
>> select "LBGE51FL".the_geom, "LBGE51FL".gid,
>> AVG(ST_Distance(ST_Transform("LBGE51FL".the_geom, 954010),
>> ST_Transform(acled.the_geom, 954010)))/1000 AS dist INTO LB_dist FROM
>> "LBGE51FL", acled WHERE acled.gwno = 450 GROUP BY "LBGE51FL".the_geom,
>> "LBGE51FL".gid;
>> SRID 954010 is Eckert VI.
>> Any idea on how to limit this query to the 10 nearest points?
>> Thanks.
>> Andreas
> Hi,
> Using a subquery to compute the distance, order by distance, limit 10,
> before computing the avg distance ?
> Nicolas
> postgis-users mailing list
