[postgis-users] rasters not read
Paolo Cavallini cavallini at faunalia.it
Tue Jan 4 08:30:41 PST 2011
Il giorno mar, 04/01/2011 alle 17.10 +0100, Jorge Arévalo ha scritto:
> So, correct me if I'm wrong...
> (I suppose after that you did psql -d yourdatabase -f drm_rt.sql)
Correct.
> You did it on December 23rd and today. And with the same version of
> GDAL, you tried to transform the PostGIS Raster in a TIFF file. With
> the db created on 23rd it worked, but with the db created today, it
> doesn't.
> Could you send me the original files you loaded in PostGIS?
I tried with several files, including the sample ones (utm.tif).
All the best.
http://www.faunalia.it/pc
