[postgis-users] Newbie Q: More efficient query for polygons near lines
Dan Lyke danlyke at flutterby.com
Tue Jan 4 08:53:17 PST 2011
I have a silly question that I can't wrap my head around doing more
efficiently (and it may not actually matter).
My example is that I have two tables, tax parcels from the county, and
the USGS streams center lines.
Say I want to select all parcels within a meter of a stream center line
(yeah, it's a silly query, as at least one of those "streams" is 25
meters wide). I can do:
  SELECT par_parcels.the_geom FROM par_parcels , hyd_usgsstrm
    WHERE ST_DWithin(par_parcels.the_geom, hyd_usgsstrm.the_geom, 1)
But that, of course, gives me multiple par_parcels.
I can also do:
  SELECT DISTINCT(par_parcels.the_geom) FROM par_parcels , hyd_usgsstrm
But what I really want is something more like:
  SELECT the_geom FROM par_parcels
    WHERE ST_DWithin(the_geom, (SELECT the_geom FROM hyd_usgsstrm), 1);
but that, of course, both doesn't let the query optimizer do anything
intelligent and gives me:
  ERROR:  more than one row returned by a subquery used as an expression
What's the right approach for this kind of query?
Thanks!
Dan
