[postgis-users] How to import/export PostGIS Raster data? Tools?
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Wed Jan 5 14:37:47 PST 2011
>>> As far as export goes, I think you are right -- we already have that
>>> in the GDAL PostGIS Raster driver, but that gave me a thought that the
>>> planned PostGIS functions ST_AsJPEG, ST_AsTiff etc Maybe should just
>> piggy back on GDAL and be callled
>>> ST_AsRasterOutputFormat(rast, 'sometype', 'options')
>>> Where sometype would be a type defined in GDAL. And options would be
>>> a string of options valid for that output format. In the end -- the
>>> output of that is just a bytea so PostgreSQL is not really going to
>>> care either way what comes out of that end.
>>> Pierre is unfortunately on a long needed vacation -- so he's not going
>>> to respond anytime soon. Jorge et. Al, any resason why this is not
>feasable?
I planned this ST_AsRasterOutputFormat since a while. I thought I had put it in the spec but apparently I didn't. (Now it's done: http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking03) I called it ST_AsGDALRaster().
>> Actually, the only dependence with GDAL is in the ST_DumpAsPolygons
>function. We could break this dependence using our polygonize function.
>Good point. Yah right now I don't even bother compiling GDAL with
>PostgreSQL support or others since it really doesn't need it for our current
>use. Which is why the gdal so/dll is all I ever need to package.
>I guess using the Tiff, etc. would require us adding additional dependencies
>since GDAL depends on tiff drivers and so forth.
>My thinkng though aside from adding more dependencies -- is I really don't
>like calling the functions ST_AsJPEG etc. It limits our future options and
>to me just creates function bloat.
I think ST_AsJPEG, ST_AsTiff, ST_AnyFormat should just be wrapper around this more general ST_AsGDALRaster() using the GDAL dll.
Yes this will increase our dependency over GDAL.
I don't think we want to/will reduce/eliminate our dependency over GDAL over time. GDAL is a library made for use by software like ours, why not using it if it serve us well. Up to now it reduced our development time for ST_DumpAsPolygons and ST_Intersection by weeks if not months.
I plan to use GDAL not only for this ST_AsGDALRaster() function but also to implement transparent use of out-of-db raster and for ST_Resample().
Beside this Paul seemed to be happy that PostGIS could now use GDAL for I don't remember which use.
>I'd much rather have the deliberateness encoded in an enum. Now that
>PostgreSQL 9.1 will allow altering enums, this will allow for infinite
>expansion of possibilities without function bloat and there are a a lot of
>raster types out there.
>http://developer.postgresql.org/pgdocs/postgres/sql-altertype.html
You will have to elaborate a bit more on this for me to understand. (Sometimes I'm very slow...)
Pierre
