[postgis-users] Querying geometries with different srid
Farrukh Najmi farrukh at wellfleetsoftware.com
Thu Jan 6 17:05:37 PST 2011
Doing some RTFM I see on the posgis page here:
http://workshops.opengeo.org/postgis-intro/projection.html
Note
Be careful of getting too happy with using *ST_Transform* for on-the-fly
conversion. Spatial indexes are built using SRID of the stored
geometries. If comparison are done in a different SRID, spatial indexes
are (often) not used. It is best practice to choose *one SRID* for all
the tables in your database. Only use the transformation function when
you are reading or writing data to external applications.
So unless I here otherwise I think above suggests that what I called
option #1 below is the best practice to follow.
On 01/06/2011 06:00 PM, Farrukh Najmi wrote:
> Hello,
> My application needs to support storing of geometry instances with
> different SRID values in the same table and then be able to query it
> using spatial operations and a filter geometry which could be in any
> SRID.
> One possible option (Option #1) is to use ST_TRANSFORM function to
> transform all geometry instances on WRITE to the same internal SRID
> (say 4326) and transform the filter geometry used by the query to the
> same SRID used internally (say 4326) before doing the spatial operation.
> The other option (Option #2) is to store all geometry instances with
> their original SRID values on WRITE and use ST_TRANSFORM function in
> the query to transform all internal geometry instances to match the
> same SRID as that of the filter geometry used by the query.
> It seems option #1 is less accurately preserving the original data but
> is much more efficient on query while option #2 stores original data
> without any change but may have serious performance issues due to the
> transform on query.
> What do people advice based upon their experience with postgis for my
> requirement and possible solution.
> Thank you for your help.
Regards,
Farrukh Najmi
Web: http://www.wellfleetsoftware.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110106/8c1e2809/attachment.html>
