[postgis-users] Create new lines from GPS points
Ralf Suhr
Ralf.Suhr at itc-halle.de
Tue Jan 11 09:15:47 PST 2011
This will work. The GPS point is never on the road geometry.
ST_Line_Substring( road,
ST_Line_Locate_Point(road, ST_ClosestPoint(gps_start, road)),
ST_Line_Locate_Point(road, ST_ClosestPoint(gps_end, road))
) AS highlight
Gr
Ralf
Am Dienstag 11 Januar 2011, 18:08:29 schrieb Ralf Suhr:
> Hi Martin.
> ST_Line_Substring(road, ST_Line_Locate_Point(road, gps_start),
> ST_Line_Locate_Point(road, gps_end)) AS highlight
> Gr
> Ralf
> Am Dienstag 11 Januar 2011, 17:46:06 schrieb Martin Fafard:
> > Ralf
> > Yes, ok for the buffer. But how to "dynamically segment" my new road
> > from my original segment?
> > Martin
> > Ralf Suhr a écrit :
> > > Hi Martin,
> > > you will not get a correct solution for this problem. Your road network
> > > and the gps points differs always.
> > > A possible "solution" is building a buffer around the streets und look
> > > für intersection with gps points and filter by direction road/points.
> > > Grouping gps points can give you the start and end point for the road.
> > > If a road is only one times driven.
> > > Gr
> > > Ralf
> > > Am Dienstag 11 Januar 2011, 17:16:18 schrieb Martin Fafard:
> > >> Hi
> > >> I have a network of roads (topological) and I receive GPS points. I
> > >> would like to create new lines who follow exactly the same path as my
> > >> road from the GPS points (to "highlight" where the GPS unit was on the
> > >> network). The problem is I need to segment the new line because the
> > >> GPS points can stop anywhere on my roads... Any advice to do this?
> > >> Thank you
> > >> Martin F
> > >> _______________________________________________
> > >> postgis-users mailing list
> > >> postgis-users at postgis.refractions.net
> > >> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110111/e42819d3/attachment.html>
