[postgis-users] left outer join not working as expected with ST_Contains
Arne Kepp
arne at tiledmarble.org
Wed Jan 12 02:49:25 PST 2011
let me prefix by saying that I am not very good with SQL, so that's
probably where the problem lies, but it seems like ST_Contains always
ends up giving me a cross join.
SELECT sample_id, sample_date, ST_AsText(point_layer.the_geom),
polygon_value
FROM point_layer
LEFT OUTER JOIN polygon_layer ON ST_Contains(polygon_layer.the_geom,
WHERE point_layer.active = 1
In plain text: I have a table of points and a table of polygons. The
polygons have a column "polygon_value" that I would like to report with
each point.
The problem is that more than one polygon can contain the point. This is
not a problem for me, as long as I can get polygon_value from one of
them. But the query above produces one row for every point/polygon
combination. So it's essentially behaving like a cross join?
Any suggestions on what I am doing wrong or how I can get the result I
am after? Using Postgis 1.3.6 on Postgresql 8.4.4
Thank you,
-Arne
