[postgis-users] left outer join not working as expected with ST_Contains
Arne Kepp
arne at tiledmarble.org
Wed Jan 12 04:01:30 PST 2011
Hi Nicklas,
My understanding of "left join" was the same, but I thought the "outer"
part would cause it to just run over the left table and try to fill in
extra columns with the right table. I now see that none of the examples
I have been looking at really covered this case. I look forward to
finding out where else I've made this incorrect assumption ;)
You are right that the old query produces the combinations that satisfy
ST_Contains, I was just not imprecise when describing it.
Thank you for spelling it out in detail, it's very much appreciated.
-Arne
On 1/12/11 12:28 PM, Nicklas Avén wrote:
> Hallo Arne
> As I understand you, you say two different things here.
> First:
> I think you are misunderstanding how left join works.
> left join is an inner join plus all remaining records of the left table.
> That means you cannot use the left join in your case to only get one
> result from many point-polygon combinations.
> Then you write:
>> But the query above produces one row for every point/polygon
>> combination. So it's essentially behaving like a cross join?
> Do you really mean it returns all combinations of points and polygons,
> or does it return all combinations that satisfy ST_Contains.
> The expected result from your query
> SELECT sample_id, sample_date, ST_AsText(point_layer.the_geom),
> polygon_value
> FROM point_layer
> LEFT OUTER JOIN polygon_layer ON ST_Contains(polygon_layer.the_geom,
> WHERE point_layer.active = 1
> is all row combinations where a point is inside any polygon plus all the
> rest of the point rows (in those cases there will be null in the fields
> from the polygon table.
> What you should do instead is using distinct on that value from the
> polygon table you want. Could look something like
> DISTINCT ON (location) location
> SELECT DISTINCT ON (sample_id) sample_id, sample_date,
> polygon_value
> FROM point_layer
> INNER JOIN polygon_layer ON ST_Contains(polygon_layer.the_geom,
> you can read about distinct here:
> http://www.postgresql.org/docs/9.0/static/sql-select.html#SQL-DISTINCT
> HTH
> Nicklas
>> Any suggestions on what I am doing wrong or how I can get the result I
>> am after? Using Postgis 1.3.6 on Postgresql 8.4.4
>> Thank you,
>> -Arne
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
