[postgis-users] Create new lines from GPS points
Martin Fafard
martin.fafard at geoprojection.com
Thu Jan 13 06:50:57 PST 2011
Hi
Last step for my problem. Following the attached jpg, I need to
highlight (create new line) the topological road (black) only when it
intersect the green line
Any advice?
Thank you
Martin
Stephen Woodbridge a écrit :
> I think this problem has some hidden assumptions about what is the
> rate of the incoming points, or more appropriately how close together
> the GPS points are and with mis-alignment of GPS with respect to high
> density road networks. If the GPS sample rate is high and the relative
> distance is small percentage of the road network segments then the
> problem is easier to solve because you can assume that any given point
> is likely on the same segment as the last point or just transitioned
> to the next segment in the network.
> There are still serious issue if there is a mis-alignment between the
> GPS data and the road segments, especially in dense road network
> areas. Here you might need to apply a stickiness to the segment you
> are one and do additional analysis and in fact defer judgment to N-1
> when looking at point N.
> Also as your sample rate spreads out and the distance between GPS
> point increases then the last segment and the current segment might
> not even be touching so you might need to route between the adjacent
> GPS points. Add to this mis-alignment issues and you have a very
> tricky problem to solve.
> The above issues are particularly prevalent in CDMA cell phone tower
> assisted GPS systems that can have a lot of error in urban areas which
> also have higher density road networks, but need to be considered with
> any system like this.
> -Steve W
> On 1/11/2011 12:15 PM, Ralf Suhr wrote:
>> This will work. The GPS point is never on the road geometry.
>> ST_Line_Substring( road,
>> ST_Line_Locate_Point(road, ST_ClosestPoint(gps_start, road)),
>> ST_Line_Locate_Point(road, ST_ClosestPoint(gps_end, road))
>> ) AS highlight
>> Gr
>> Ralf
>> Am Dienstag 11 Januar 2011, 18:08:29 schrieb Ralf Suhr:
>> > Hi Martin.
>> > ST_Line_Substring(road, ST_Line_Locate_Point(road, gps_start),
>> > ST_Line_Locate_Point(road, gps_end)) AS highlight
>> > Gr
>> > Ralf
>> > Am Dienstag 11 Januar 2011, 17:46:06 schrieb Martin Fafard:
>> > > Ralf
>> > > Yes, ok for the buffer. But how to "dynamically segment" my new
>> road
>> > > from my original segment?
>> > > Martin
>> > > Ralf Suhr a écrit :
>> > > > Hi Martin,
>> > > > you will not get a correct solution for this problem. Your road
>> network
>> > > > and the gps points differs always.
>> > > > A possible "solution" is building a buffer around the streets und
>> look
>> > > > für intersection with gps points and filter by direction
>> road/points.
>> > > > Grouping gps points can give you the start and end point for the
>> road.
>> > > > If a road is only one times driven.
>> > > > Gr
>> > > > Ralf
>> > > > Am Dienstag 11 Januar 2011, 17:16:18 schrieb Martin Fafard:
>> > > >> Hi
>> > > >> I have a network of roads (topological) and I receive GPS
>> points. I
>> > > >> would like to create new lines who follow exactly the same path
>> as my
>> > > >> road from the GPS points (to "highlight" where the GPS unit was
>> on the
>> > > >> network). The problem is I need to segment the new line
>> because the
>> > > >> GPS points can stop anywhere on my roads... Any advice to do
>> this?
>> > > >> Thank you
>> > > >> Martin F
>> > > >> _______________________________________________
>> > > >> postgis-users mailing list
>> > > >> postgis-users at postgis.refractions.net
>> > > >> http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110113/36663586/attachment.jpe>
