[postgis-users] Querying geometries with different srid
Farrukh Najmi farrukh at wellfleetsoftware.com
Fri Jan 14 06:49:12 PST 2011
Hi Ture,
Thanks for the advice. Unfortunately WITH is not supported in postgres
8.3. So I could not try it out.
Any other ideas?
On 01/14/2011 12:38 AM, Ture Pålsson wrote:
> 2011/1/14 Farrukh Najmi<farrukh at wellfleetsoftware.com>:
>>> --Gives Error: Operation on mixed geometries
>>> SELECT * FROM GeometryValueType gvt WHERE ( ST_SRID(gvt.geometry) = 4326
>>> AND
>>>   within(gvt.geometry, ST_GeomFromText('POLYGON((-100 0, 0 0, 0 100, -100
>>> 100, -100 0))', 4326)) = true )
> Does SQL guarantee left-to-right evaluation and short-circuiting of
> AND checks the way that C does? I must confess I have no clue.
> However, if it doesn't, that might be what's causing your headaches.
> I'd try moving the SRID filter into a WITH construct or a sub-select
> just to see what happens:
> WITH filteredgeom AS (
>    SELECT * FROM gvt WHERE ST_SRID(geometry) = 4326)
> SELECT * FROM filteredgeom WHERE within(geometry, ...) ;
> Probably lots of syntax errors (haven't had breakfast yet) but you get
> the idea...
>    -- Ture
> postgis-users mailing list
Regards,
Farrukh Najmi
Web: http://www.wellfleetsoftware.com
