[postgis-users] Querying geometries with different srid
Farrukh Najmi
farrukh at wellfleetsoftware.com
Fri Jan 14 07:33:33 PST 2011
Hi Ralph,
Thanks so very much for your help.
In my PG 8.3 PostGIS 1.3.3 setup when I try to run explain on the nested
select version of my query I get:
Nested Loop IN Join (cost=0.00..2.69 rows=1 width=358)
Join Filter: (gvt.id = gvt1.id)
-> Seq Scan on geometryvaluetype gvt (cost=0.00..1.33 rows=1
width=358)
Filter: (st_srid(geometry) = 4326)
-> Seq Scan on geometryvaluetype gvt1 (cost=0.00..1.27 rows=7 width=8)
Filter: within(gvt1.geometry,
'0103000020E6100000010000000500000000000000000059C00000000000000000000000000000000000000000000000000000000000000000000000000000594000000000000059C0000000000000594000000000000059C00000000000000000'::geometry)
(6 rows)
Based on above it seems I am first filtering on SRID - No?
What am I missing?
Can you tell me what my query should look like to make it work?
On 01/14/2011 10:12 AM, Ralf Suhr wrote:
> Hi Farrukh,
> you have to first check for the right srid before you can compare the bbox. If
> you use the SQL command EXPLAIN for your query yyou can see what will be done.
> SELECT *
> FROM GeometryValueType gvt
> WHERE gvt.id IN (
> SELECT gvt1.id
> FROM GeometryValueType gvt1
> WHERE ST_SRID(gvt.geometry) = 4326
> ) AND Within(gvt1.geometry, ST_GeomFromText('POLYGON((-100 0, 0 0, 0
> 100, -100 100, -100 0))', 4326)) = true;
> Gr
> Ralf
> Am Freitag 14 Januar 2011, 15:55:31 schrieb Farrukh Najmi:
>> BTW, using nested SELECT did not work either as shown in follow query:
>> SELECT * FROM GeometryValueType gvt WHERE
>> ST_SRID(gvt.geometry) = 4326 AND gvt.id IN (
>> SELECT gvt1.id FROM GeometryValueType gvt1 WHERE
>> within(gvt1.geometry, ST_GeomFromText('POLYGON((-100 0, 0 0, 0
>> It again gives the "Operation on mixed SRID geometries" error :-(
>> It seems to me that surely this should be doable. If it is not doable,
>> do folks think that is an issue that should be tracked?
>> On 01/14/2011 09:49 AM, Farrukh Najmi wrote:
>>> Hi Ture,
>>> Thanks for the advice. Unfortunately WITH is not supported in postgres
>>> 8.3. So I could not try it out.
>>> Any other ideas?
>>> On 01/14/2011 12:38 AM, Ture Pålsson wrote:
>>>> 2011/1/14 Farrukh Najmi<farrukh at wellfleetsoftware.com>:
>>>>>> --Gives Error: Operation on mixed geometries
>>>>>> SELECT * FROM GeometryValueType gvt WHERE ( ST_SRID(gvt.geometry) =
>>>>>> 4326
>>>>>> AND
>>>>>> within(gvt.geometry, ST_GeomFromText('POLYGON((-100 0, 0 0, 0
>>>>>> 100, -100
>>>>>> 100, -100 0))', 4326)) = true )
>>>> Does SQL guarantee left-to-right evaluation and short-circuiting of
>>>> AND checks the way that C does? I must confess I have no clue.
>>>> However, if it doesn't, that might be what's causing your headaches.
>>>> I'd try moving the SRID filter into a WITH construct or a sub-select
>>>> just to see what happens:
>>>> WITH filteredgeom AS (
>>>> SELECT * FROM gvt WHERE ST_SRID(geometry) = 4326)
>>>> SELECT * FROM filteredgeom WHERE within(geometry, ...) ;
>>>> Probably lots of syntax errors (haven't had breakfast yet) but you get
>>>> the idea...
>>>> -- Ture
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Farrukh Najmi
Web: http://www.wellfleetsoftware.com
