[postgis-users] why st_isclosed() is false?
Birgit Laggner
birgit.laggner at vti.bund.de
Mon Jan 17 23:52:47 PST 2011
Hallo Ralf,
thank you! I didn't notice that. So, I should remove the end points in
both linestrings or perhaps remove the linestrings at all... I will see...
Regards,
Birgit.
On 17.01.2011 16:10, Ralf Suhr wrote:
> Hallo Birgit,
> your Multilinestring can not be convert to a valid linestring. ST_Linemerge
> give not a Linestring.
> The parts 2 and 3 have the same start and endpoint
> Gr
> Ralf
> Am Montag 17 Januar 2011, 15:51:49 schrieb Birgit Laggner:
>> Dear list,
>> perhaps somebody could clear things for me:
>> If I run the query below, the result is "false". But I don't understand
>> why. I always thought, as long as there exists a continuous chain of
>> start and end points, a MultiLineString would be closed. Am I wrong
>> somehow?
>> Thanks and regards,
>> Birgit.
>> select st_isclosed(st_geomfromtext(
>> 'MULTILINESTRING(
>> (3584442.63274253 5842172.41579578,
>> 3584358.9809 5842152.7361,
>> 3584355.23337321 5842153.70245931),
>> (3584355.23337321 5842153.70245931,
>> 3584355.23330909 5842153.70247585,
>> 3584355.23339452 5842153.70245382,
>> 3584348.03488658 5842155.55873215,
>> 3584345.68905341 5842155.07665686,
>> 3584343.82931858 5842154.69447615,
>> 3584340.46724669 5842152.9072508,
>> 3584338.14023057 5842151.67024508,
>> 3584328.33210257 5842146.45639614,
>> 3584009.05607027 5842072.59988407,
>> 3583887.98803815 5842042.75796404,
>> 3583790.05011806 5842106.6478841,
>> 3583790.05012 5842106.64788453,
>> 3583878.43617231 5842126.47539268,
>> 3584324.73120656 5842226.59207621,
>> 3584329.67415529 5842229.44269127,
>> 3584334.41005457 5842232.17390022,
>> 3584368.1119426 5842240.76423623,
>> 3584463.63629469 5842262.81966025,
>> 3584488.97911407 5842268.84731974),
>> (3584488.97911407 5842268.84731974,
>> 3584488.97978147 5842268.84747848,
>> 3584488.97978146 5842268.84747848,
>> 3584488.97890809 5842268.84727075,
>> 3584464.1099 5842262.3082,
>> 3584464.10990818 5842262.30817579,
>> 3584466.07027273 5842256.50678355,
>> 3584472.08934014 5842238.694295,
>> 3584472.08940751 5842238.69409565,
>> 3584489.545 5842187.037,
>> 3584489.5450305 5842187.03700481,
>> 3584489.54503071 5842187.03700417,
>> 3584526.86014482 5842192.92533864,
>> 3584514.30279074 5842190.12385218,
>> 3584495.65165472 5842186.30586817,
>> 3584480.67207071 5842180.87201217,
>> 3584458.64642469 5842176.18313362,
>> 3584458.64634269 5842176.18311617,
>> 3584442.63469631 5842172.41625542,
>> 3584442.63274253 5842172.41579578))',31467));
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
