[postgis-users] Build PostGIS 1.5.2 under Windows
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Jan 19 03:19:43 PST 2011
On 18/01/11 19:39, Ilie, Radu wrote:
> Hi,
> We need to build PostGIS 1.5.2 as 32 bit under Windows, using Visual C++.
> We tried to follow the instructions from
> http://trac.osgeo.org/postgis/wiki/DevWikiWinVC_15, but the instructions
> from there are not complete. We tried to follow the logical path from
> the end of the instructions, but we get thousands of compilation errors.
> I noticed at http://www.postgis.org/download/windows/experimental.php
> that there are binaries available for distribution under Windows. I
> imagine the people building them have a build environment for Windows
> already set up. Does anybody know the steps followed by the people that
> build the Windows binaries?
> Are there any updated instructions available for building PostGIS under
> Windows? Even if they are cumbersome, we can follow them.
> Thank you,
Sadly MSVC builds under Windows are currently unsupported, however if
you do manage to get any further please do update the wiki with your
progress. Is there any particular reason that you can't use the MingW
builds?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
