[postgis-users] Help with a multipolygon filtering function
Nicklas Avén
nicklas.aven at jordogskog.no
Thu Jan 20 01:37:47 PST 2011
I should ignori it, but I had to correct a typo, the last query I think
should be:
Select st_collectionextract(st_collect(whole_table.the_geom), 3)
from
(Select (st_dump(the_geom)).geom as the_geom,(st_dump(the_geom)).path as
the_path, id from myTable) as whole_table
left join
(SELECT a.the_path, a.id FROM
(SELECT (st_dump(the_geom)).geom as the_geom ,(st_dump(the_geom)).path
as the_path, id from myTable) as a
left join
(SELECT (st_dump(the_geom)).geom as the_geom, id from myTable) as b
on st_dwithin(a.the_geom, b.the_geom, theDistance)
where b.id is null) too_far_away
on whole_table.id=too_far_away.id and
whole_table.the_path=too_far_away.path
where too_far_away.path is null
group by whole_table.id;
/Nicklas
> I want to clean up some multipolygons and remove any polygons over a
> certain
> distance by using a postgis function.
> This is the closest I've come:
> CREATE OR REPLACE FUNCTION filter_polygons_within(geometry, double
> precision)
> RETURNS geometry AS
> $BODY$
> SELECT ST_Multi(ST_Collect(final_geom.poly)) AS filtered_geom
> FROM (
> SELECT DISTINCT a.poly
> FROM (
> SELECT ST_GeometryN(ST_Multi($1), generate_series(1,
> ST_NumGeometries(ST_Multi($1)))) AS poly,
> (SELECT ST_GeometryN(ST_Multi($1), generate_series(1,
> ST_NumGeometries(ST_Multi($1))))) as poly_b
> ) AS a
> WHERE a.poly != a.poly_b
> AND ST_DWithin(a.poly, a.poly_b, $1)
> ) as final_geom
> $BODY$
> LANGUAGE 'sql' IMMUTABLE;
> However, the where clause isn't working for me - any ideas on how to
> achieve
> this? I'm not sure on how to compare all polygons with each other, I
> know
> how to get a list of polygons;
> I'm just not sure how to compare each one with another and return the
> distinct polygon results.
> Thanks in advance,
> Ross
> postgis-users mailing list
