[postgis-users] WKTRaster problems on Mac
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Jan 21 06:38:01 PST 2011
Ken,
I tried the .img file you sent me and everything seems ok.
What did you use to produce this image? I suspect the image is well stored but the renderer you are using have some problems.
To display images I use OpenJump and so a query like:
SELECT ST_AsBinary((gv).geom), (gv).val
FROM (SELECT ST_DumpAsPolygons(rast) gv FROM x01) foo
to the database.
Pierre
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ken Nussear
Sent: 20 janvier 2011 12:41
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] WKTRaster problems on Mac
Hi all.
I've been working with the gdal2wktraster.py script trying to load some rasters to see it things work, and I'm having some difficulty.
The example from the tutorial using the utml.tif tile seems to work fine, but every other raster I've tried gives strange results.
Some show as all one value, and others appear to have irregular patches of values in the block sizes imported.
I have tried tif, png, and img files some come in as pictured below, and some just come in with single values (e.g. 8 for all cells). Some have ridiculous numbers (e.g. 2.8026e-45)
Some examples attached.
I'm using a mac with postgis from William Kyngesburye @ kyngchaos.com<http://kyngchaos.com>
postgresql version 9.0.2-1
postgis version 1.5.2-2
WKTRaster 0.1.6d r5997 for Postgres 9.0
commands used:
/usr/local/pgsql/bin/gdal2wktraster.py -r D2BDRK_SLP_SAAT.img -t d2bdrk -k 32x32 -o d2bdrk.sql -s 26911 -I -M
/usr/local/pgsql/bin/psql -d brdgisR -f d2bdrk.sql -U postgres -w
I wonder if you have any advice on what might be going wrong?
Thanks
Ken
[cid:image001.png at 01CBB94E.7E398E80]
[cid:image002.png at 01CBB94E.7E398E80]
[cid:image003.png at 01CBB94E.7E398E80]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110121/977d054e/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110121/977d054e/attachment.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110121/977d054e/attachment-0001.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110121/977d054e/attachment-0002.png>
