[postgis-users] Using cleangeometry() on only the Multipolygons in a field of type geometry
strk
strk at keybit.net
Tue Jan 25 00:46:20 PST 2011
On Mon, Jan 24, 2011 at 09:35:52PM -0500, Pete Yunker wrote:
> We have a field of type geometry containing both Multipolygon and Point entities. How can cleangeometry be used on only the Multipolygons, since cleangeometry cannot be used on a field of type geometry?
> The following query fails with "ERROR: function cleangeometry(geometry) does not exist"
> 1.3.6 PostGIS
> 3.1.0 GEOS
cleangeometry is a contributed procedure.
PostGIS itself has an ST_MakeValid, which does a similar thing, but
only starting with version 2.0.0 (available trough the source
repository, but not released yet).
You might have missed to install the contributed procedure, which I guess
you found on the PostGIS wiki.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
