[postgis-users] Strange behavior with a polygon and line that claim	to intersect ....
    Bryan Montgomery
    monty at english.net
    Tue Jan 25 12:00:28 PST 2011
Hello,
Is there a way to debug a problem I have with a polygon and line? I was
running a query that used st_intersects and st_intersection to get the
length of lines that are within the polygon. I was spot checking some of the
data and came up with a particularly strange example.
Visually, the polygon looks as it should, the line clearly appears to be
completely contained within the polygon however st_crosses returns true and
intersection returns a subset of the line. I've tried this on postgis
version 1.3 and 1.4 and both behave the same. I'm inclined to believe there
is a stray point but given the polygon 2,700+ points I'm not sure how I find
it! I suppose it's possible that there is a bug - or maybe I'm just
completely missing something.
I tried finding the closest point on the polygon to the line - but when I
tried to find a way to do this it seemed that the suggestions were for
finding the closest point when the other point was outside the polygon?
Appreciate any help,
Thanks - Bryan.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110125/62c00100/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110125/62c00100/attachment.zip>
