[postgis-users] Update field from expression
Poynter, David
POYNTER at adeq.state.ar.us
Fri Jan 28 10:24:26 PST 2011
I believe it was Ture who asked the rhetorical question, and it was a good one. The update query as I did it did not work correctly, the updated field ended up a single value. The query as Birgit did it worked as expected and was much faster to boot.
Thanks to all for your help,
david
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Birgit Laggner
Sent: Friday, January 28, 2011 6:19 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Update field from expression
Hi Nicolas,
you're right - I've made this mistake very often myself...
If there can be only one polygon for each point where st_within turns
true for (which I assume), then this form of the query may solve that
problem:
UPDATE permit_sites p_s SET huc = giddy.h_gid FROM (SELECT p.gid p_gid, h.gid h_gid FROM permit_sites p inner join huc8 h on p.the_geom @ h.the_geom
WHERE ST_Within(p.the_geom,h.the_geom)) AS giddy WHERE p_s.gid=giddy.p_gid;
I hope, I made no mistake...
Regards,
Birgit.
On 28.01.2011 10:55, Ture Pålsson wrote:
> 2011/1/28 Nicolas Ribot<nicolas.ribot at gmail.com>:
>> UPDATE permit_sites SET huc = giddy.gid FROM (SELECT h.gid FROM huc8 h,
>> permit_sites p WHERE ST_Within(p.the_geom,h.the_geom)) AS giddy;
> Let me ask a rhetorical question: Which row from the inner SELECT gets
> connected to which row of the table being updated?
> postgis-users mailing list
