[postgis-users] PostGIS Raster Performance
Paragon Corporation
lr at pcorp.us
Sat Jan 29 14:30:37 PST 2011
Sunny,
Good question. I suspect it will be worse at least at the moment (just as
PostGIS was worse when it first came out than reading from shapefile). How
much worse I'm not sure. If you try and see speed issues, we can tackle
them, but it hasn't really been our main focus.
I suspect no one has tested it extensively as far as dishing out large
datasets. The primary focus of PostGIS Raster is for analysis and then
secondary is the rendering. That is not to say it will work badly or we
don't care about rendering speed, just that the GDAL drivers etc. needed by
Mapserver probably still have a few wrinkles which would make it suboptimal
for that kind of work. The more people use it and find issues, the faster
issues will be addressed since we would have data points to go by.
As far as GeoServer goes, I recall reading a thread where Chris Holmes said
he would work on a PostGIS Raster support for GeoServer, but not sure where
that is down the pipe, but to my knowledge, GeoServer does not YET support
PostGIS raster.
Hope that helps,
Regina
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sunny
Teo
Sent: Saturday, January 29, 2011 3:44 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostGIS Raster Performance
List,
Can anyone comment on the "Performance" of the PostGIS Rater or WKTRaster ?
If you were to serve this onto a web application, how effective are they?
Well, I'm talking of very large datasets like 10GB each and 100 of them. How
does it compare with serving the images as files directly.. from a GeoTIFF,
ECW, Sid, etc. (obviously using Geoserver/Mapserver or some specialized
image serving solution)
Been searching all over the web for the answers, but no luck.
Hope to get some insights from the users.
Thank you;
Sunny.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110129/24533016/attachment.html>
