[postgis-users] minimum value of the query result
Brian Sanjeewa Rupasinghe jinkabs at gmail.com
Sun Jul 3 09:29:25 PDT 2011
I retreive minimum x of each bounding box of some polygons using following
query:
SELECT (min(ST_XMin(BOX2D((ST_Dump(the_geom)).geom)))) as XMin
from building_poly;
How can i find the minimum X of all Xmin coordinatges? Can i use min()?
Cheers, Sanjeewa.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110703/cb9b4ed1/attachment.html>
