[postgis-users] Newbie - Spatial Join with a large dataset
James David Smith
james.david.smith at gmail.com
Mon Jul 11 02:20:39 PDT 2011
Hey Rich,
I'm a newbie myself, but it seems to me that you either need a table
that defines the geometry of the continents (so that you can do a
spatial join with the points), or the points table itself needs a
column which tells you in which continent that point is located. Do
you have either of these at the moment?
Cheers
James
On 10 July 2011 20:34, Rich B <richisgeo at gmail.com> wrote:
> Hello all,
> I have a newbie question for you guys…here goes :
> I have a large dataset (a geonames world data-dump) that I’ve imported into
> Postgis.
> I want to know how to do a Spatial Join with this dataset so that I can
> split the millions of points up into chunks by continent.
> For example :
> A user connects to the database in QGIS and wants to select all of the
> cities (I’m going to trim the data down a little more using a query later
> on) and they want to bring in only the points that fall in Europe or Africa.
> In a nutshell I want a user to select all the points by continent instead of
> loading the whole dataset.
> I’m sure there’s an easy way to do this , and I’m probably going to slap
> myself for not thinking of this earlier.
> I’m relatively new to OSGIS and I’m getting the hang of it. I’ve been an
> ESRI guy for a while.
> Thanks in advance for the feedback.
> Cheers!!!
> postgis-users mailing list
