[postgis-users] Newbie - Spatial Join with a large dataset
Rich B
richisgeo at gmail.com
Mon Jul 11 10:54:57 PDT 2011
Thank you!
Yes I do have both of those datasets. I'll run the spatial join that way and see what happens.
*fingers crossed*
On Jul 11, 2011, at 5:20 AM, James David Smith <james.david.smith at gmail.com> wrote:
> Hey Rich,
> I'm a newbie myself, but it seems to me that you either need a table
> that defines the geometry of the continents (so that you can do a
> spatial join with the points), or the points table itself needs a
> column which tells you in which continent that point is located. Do
> you have either of these at the moment?
> Cheers
> James
> On 10 July 2011 20:34, Rich B <richisgeo at gmail.com> wrote:
>> Hello all,
>> I have a newbie question for you guys…here goes :
>> I have a large dataset (a geonames world data-dump) that I’ve imported into
>> Postgis.
>> I want to know how to do a Spatial Join with this dataset so that I can
>> split the millions of points up into chunks by continent.
>> For example :
>> A user connects to the database in QGIS and wants to select all of the
>> cities (I’m going to trim the data down a little more using a query later
>> on) and they want to bring in only the points that fall in Europe or Africa.
>> In a nutshell I want a user to select all the points by continent instead of
>> loading the whole dataset.
>> I’m sure there’s an easy way to do this , and I’m probably going to slap
>> myself for not thinking of this earlier.
>> I’m relatively new to OSGIS and I’m getting the hang of it. I’ve been an
>> ESRI guy for a while.
>> Thanks in advance for the feedback.
>> Cheers!!!
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
