[postgis-users] Mapserver connection to Postgis Raster
Jorge Arévalo
jorge.arevalo at deimos-space.com
Mon Jun 6 01:01:12 PDT 2011
Did you test using single quotes surrounding at least the table name?
The blank spaces may cause problems.
Best regards,
Jorge
On Sun, Jun 5, 2011 at 11:03 PM, Virginia Maffei <vmaffei at gmail.com> wrote:
> Hi, I installed again de postgis 2.0 and now i could load al the .sql with
> the makepostgisdb.bat that de windows version brings. The only thing is that
> i had to first create de DB and then in a separate .bat run the .sql load.
> I installed gdal 1.8 and also have de gdal 1.8 in the mapserver (ms4w 3.0.2)
> installation, but i cant connect with the data base i'm trying to run a
> gdal_translate or gdal_info and it doesnt work. I created a new data base
> having as template the one loaded with the postgis 2.0
> This is the error that it shows:
> C:\ms4w\tools\gdal-ogr>gdal_translate PG:"dbname=raster user=postgres
> table=Hume
> dadDeExtincion mode=2" C:\TSIG\capas\sql2\HumedadDeExtincion.tif
> ERROR 1: Error browsing database for PostGIS Raster properties
> GDALOpen failed - 1
> Any way...i will post this problem in another thread because the subject is
> different.
> regards,
> Virginia
> 2011/6/3 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> [SP] Hola Virginia. Realmente el único español, que yo sepa, soy yo,
>> así que si no te importa, voy a responder a tu pregunta en inglés
>> [EN] Hi Virginia, AFAIK, I'm the only Spanish on the list. So, I'm
>> going to answer your question in english.
>> Are you sure you loaded all the needed sql files? These are
>> postgis.sql, spatial_ref_sys.sql and rtpostgis.sql
>> Best regards,
>> Jorge
>> On Thu, Jun 2, 2011 at 11:36 PM, Virginia Maffei <vmaffei at gmail.com>
>> wrote:
>> > Hola! estoy intentando cargar manualmente el raster support y estoy
>> > ejecutando el rtpostgissql que trae el postgis2.0
>> > Pero al ejecutarlo me tira que no existe la funcion box2d(raster)
>> > Alguna idea de que puede estar pasando?
>> > Gracias!
>> > PD: Escribí en español porque me pareció ver que son de españa y yo en
>> > realidad hablo en español.
>> > saludos!
>> > Virginia
>> > On Thu, Jun 2, 2011 at 11:16 AM, Virginia Maffei <vmaffei at gmail.com>
>> > wrote:
>> >> Thank you!! I will try that installation
>> >> Virginia
>> >> 2011/6/2 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> >>> On Thu, Jun 2, 2011 at 3:25 PM, Virginia Maffei <vmaffei at gmail.com>
>> >>> wrote:
>> >>> > Thank you for your quick response!
>> >>> > I have another question: can i install postgis 2.0 in windows? where
>> >>> > can I
>> >>> > download it?
>> >>> > Virginia
>> >>> Yes, you can. Follow this post's instructions:
>> >>> http://gis4free.wordpress.com/2011/03/10/how-to-install-and-configure-postgis-raster-on-windows/
>> >>> Best regards,
>> >>> Jorge
>> >>> >> Hi,
>> >>> >> The mode=2 parameter is only valid with the last version of GDAL
>> >>> >> (1.8.0). So, as Regina said, you need that version to make it work
>> >>> >> properly. More accurately:
>> >>> >> - With a GDAL version down to 1.7.1, you can't make it work in any
>> >>> >> way. No driver.
>> >>> >> - With a GDAL version between 1.7.1 and 1.7.3, both included, you
>> >>> >> can
>> >>> >> use the old version of the driver, thought to work with the old
>> >>> >> wktraster extension, now abandoned. And it was buggy. Not
>> >>> >> recommended.
>> >>> >> Neither GDAL 1.7.x nor wktraster.
>> >>> >> - With GDAL version up to 1.8.0, you can use the last version of
>> >>> >> GDAL
>> >>> >> PostGIS Raster driver, and you'll need PostGIS 2.0, that includes
>> >>> >> PostGIS Raster extension. Additionally, as Regina said, those days
>> >>> >> we're working on the driver, and all the improvements will be
>> >>> >> included
>> >>> >> in GDAL 1.8.x
>> >>> >> So, summarizing: You need PostGIS 2.0 plus GDAL 1.8.0 to make it
>> >>> >> work.
>> >>> >> Further information on the driver:
>> >>> >> http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html
>> >>> >> Best regards,
>> >>> >> Jorge
>> >>> >> On Thu, Jun 2, 2011 at 6:53 AM, Paragon Corporation <lr at pcorp.us>
>> >>> >> wrote:
>> >>> >> > Virginia,
>> >>> >> > I think you are missing a mode='2' in your connection. That was
>> >>> >> > a
>> >>> >> > new
>> >>> >> > requirement that was added for GDAL 1.8+
>> >>> >> > Try putting that in. I think the speed on the loading still
>> >>> >> > needs
>> >>> >> > quite
>> >>> >> > a
>> >>> >> > bit of work though last I tried. The speed issues will hopefully
>> >>> >> > be
>> >>> >> > resolved before 2.0 release.
>> >>> >> > Thanks,
>> >>> >> > Regina
>> >>> >> > http://www.postgis.us
>> >>> >> > ________________________________
>> >>> >> > From: postgis-users-bounces at postgis.refractions.net
>> >>> >> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf
>> >>> >> > Of
>> >>> >> > Virginia
>> >>> >> > Maffei
>> >>> >> > Sent: Wednesday, June 01, 2011 8:00 PM
>> >>> >> > To: postgis-users at postgis.refractions.net
>> >>> >> > Subject: [postgis-users] Mapserver connection to Postgis Raster
>> >>> >> > Hi, i'm new at this and i'm trying to connect to postgis raster
>> >>> >> > in
>> >>> >> > the
>> >>> >> > mapfile.
>> >>> >> > I loaded a tif file into postgis raster database with the
>> >>> >> > raster2pgsql.py
>> >>> >> > script. It created a table with 2 fields: rid and rast.
>> >>> >> > In the mapfile i added the connection like it specifies in the
>> >>> >> > postgis
>> >>> >> > raster FAQ but it doesn't displays anything.
>> >>> >> > This is my mapfile:
>> >>> >> > MAP
>> >>> >> > IMAGETYPE PNG24
>> >>> >> > EXTENT 366582.2901411663 6127927.100382689
>> >>> >> > 857582.2901411663
>> >>> >> > 6670927.100382689
>> >>> >> > SIZE 491 543
>> >>> >> > SHAPEPATH "../data"
>> >>> >> > LAYER # MODIS raster layer begins here
>> >>> >> > NAME modis
>> >>> >> > TYPE RASTER
>> >>> >> > STATUS ON
>> >>> >> > DATA "PG:host=localhost port=5432 dbname='postgis'
>> >>> >> > user='postgres'
>> >>> >> > password='postgres' schema='public' table='HumedadDeExtincion'"
>> >>> >> > PROCESSING "NODATA=0"
>> >>> >> > PROCESSING "SCALE=AUTO"
>> >>> >> > PROCESSING "SCALE_BUCKETS=201"
>> >>> >> > PROCESSING "BANDS=1"
>> >>> >> > OFFSITE 71 74 65
>> >>> >> > CLASS
>> >>> >> > NAME "red"
>> >>> >> > EXPRESSION ([pixel] < 10)
>> >>> >> > COLOR 255 0 0
>> >>> >> > END
>> >>> >> > CLASS
>> >>> >> > NAME "green"
>> >>> >> > EXPRESSION ([pixel] >= 10 AND [pixel] < 15000 )
>> >>> >> > COLOR 0 255 0
>> >>> >> > END
>> >>> >> > CLASS
>> >>> >> > NAME "blue"
>> >>> >> > EXPRESSION ([pixel] >= 15000 )
>> >>> >> > COLOR 0 255 0
>> >>> >> > END
>> >>> >> > END # MODIS raster layer ends here
>> >>> >> > # End of LAYER DEFINITIONS -------------------------------
>> >>> >> > END # All map files must come to an end just as all other things
>> >>> >> > must
>> >>> >> > come
>> >>> >> > to...
>> >>> >> > I have gdal 1.6 , postgis 1.5 and ms4w with mapserver 5.6.6
>> >>> >> > We cant see the tiff file on the browser, it only appears a white
>> >>> >> > image.
>> >>> >> > We did try with the tif without the database connection an it
>> >>> >> > works.
>> >>> >> > Could you help us?
>> >>> >> > Thank you
>> >>> >> > _______________________________________________
>> >>> >> > postgis-users mailing list
>> >>> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> >>> >> Jorge Arévalo
>> >>> >> Internet & Mobilty Division, DEIMOS
>> >>> >> http://es.linkedin.com/in/jorgearevalo80
>> >>> >> http://mobility.grupodeimos.com/
>> >>> >> http://geohash.org/ezjqgrgzz0g
>> >>> Jorge Arévalo
>> Jorge Arévalo
Jorge Arévalo
