[postgis-users] Mapserver connection to Postgis Raster
Paragon Corporation lr at pcorp.us
Mon Jun 6 18:24:27 PDT 2011
Virginia,
Looking at what you have here. I think what Leo was thinking was right.
Your table is mixed case.  When you put it in gdal_translate without
quoting, it becomes lower case so can't find the table.
It's best to just lowercase your tables in the database as he had
suggestedin the prior email.  It will save you a great deal of grief in the
future.  As you have it currently you will always have to
quote "HumedadDeExtinction"
Hope that helps,
Regina and Leo,
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Virginia
Maffei
Sent: Monday, June 06, 2011 9:06 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Mapserver connection to Postgis Raster
I attached the sql.
I hope this could help to
find out whats happening.
This is what raster_columns has:
"r_table_catalog";"r_table_schema";"r_table_name";"r_column";"srid";"pixel_t
ypes";"out_db";"regular_blocking";"nodata_values";"scale_x";"scale_y";"block
size_x";"blocksize_y";"extent"
"";"public";"HumedadDeExtincion";"rast";-1;"{64BF}";f;f;"";1000;-1000;;;""
thanks!
Virginia
2011/6/6 Jorge Arévalo <jorge.arevalo at deimos-space.com>
No, the driver doesn't need an empty entry in raster_columns table. It
only checks for raster_columns' existence. This is one of the things
I'm going to delete from the driver's code.
Virginia, raster_columns table is used in PostGIS Raster extension, to
store metadata, but the driver doesn't use it. I don't think that's
the problem. Could you send me the SQL code for your raster table? The
code generated by raster2pgsql script.
Best regards,
Jorge
On Mon, Jun 6, 2011 at 4:14 PM, Virginia Maffei <vmaffei at gmail.com> wrote:
> Sorry but i didn't understand very well. In the raster_columns table i
have
> an entry for this table.
> I dont now if i'm answering you question.
> Virginia
> On Mon, Jun 6, 2011 at 10:54 AM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>
> wrote:
>> Would it be possible that the driver needs a missing  entry in the
>> raster_columns table?
>> > -----Original Message-----
>> > bounces at postgis.refractions.net] On Behalf Of Jorge Arévalo
>> > Sent: Monday, June 06, 2011 4:01 AM
>> > Hi,
>> > Did you test using single quotes surrounding at least the table name?
>> > The blank spaces may cause problems.
>> > Best regards,
>> > Jorge
>> > On Sun, Jun 5, 2011 at 11:03 PM, Virginia Maffei <vmaffei at gmail.com>
>> > wrote:
>> > > Hi, I installed again de postgis 2.0 and now i could load al the .sql
>> > > with the makepostgisdb.bat that de windows version brings. The only
>> > > thing is that i had to first create de DB and then in a separate .bat
>> > > run the .sql
>> > load.
>> > > I installed gdal 1.8 and also have de gdal 1.8 in the mapserver (ms4w
>> > > 3.0.2) installation, but i cant connect with the data base i'm trying
>> > > to run a gdal_translate or gdal_info and it doesnt work. I created a
>> > > new data base having as template the one loaded with the postgis 2.0
>> > > This is the error that it shows:
>> > > C:\ms4w\tools\gdal-ogr>gdal_translate PG:"dbname=raster user=postgres
>> > > table=Hume dadDeExtincion mode=2"
>> > > C:\TSIG\capas\sql2\HumedadDeExtincion.tif
>> > > ERROR 1: Error browsing database for PostGIS Raster properties
>> > > GDALOpen failed - 1 Error browsing database for PostGIS Raster
>> > > properties
>> > > Any way...i will post this problem in another thread because the
>> > > subject is different.
>> > > regards,
>> > > Virginia
>> > > 2011/6/3 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> > >> [SP] Hola Virginia. Realmente el único español, que yo sepa, soy yo,
>> > >> así que si no te importa, voy a responder a tu pregunta en inglés
>> > >> [EN] Hi Virginia, AFAIK, I'm the only Spanish on the list. So, I'm
>> > >> going to answer your question in english.
>> > >> Are you sure you loaded all the needed sql files? These are
>> > >> postgis.sql, spatial_ref_sys.sql and rtpostgis.sql
>> > >> Best regards,
>> > >> Jorge
>> > >> On Thu, Jun 2, 2011 at 11:36 PM, Virginia Maffei <vmaffei at gmail.com>
>> > >> wrote:
>> > >> > Hola! estoy intentando cargar manualmente el raster support y
estoy
>> > >> > ejecutando el rtpostgissql que trae el postgis2.0 Pero al
>> > >> > ejecutarlo me tira que no existe la funcion box2d(raster) Alguna
>> > >> > idea de que puede estar pasando?
>> > >> > Gracias!
>> > >> > PD: Escribí en español porque me pareció ver que son de españa y
yo
>> > >> > en realidad hablo en español.
>> > >> > saludos!
>> > >> > Virginia
>> > >> > On Thu, Jun 2, 2011 at 11:16 AM, Virginia Maffei
>> > >> > wrote:
>> > >> >> Thank you!! I will try that installation Virginia
>> > >> >> 2011/6/2 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> > >> >>> On Thu, Jun 2, 2011 at 3:25 PM, Virginia Maffei
>> > >> >>> wrote:
>> > >> >>> > Thank you for your quick response!
>> > >> >>> > I have another question: can i install postgis 2.0 in windows?
>> > >> >>> > where
>> > >> >>> > can I
>> > >> >>> > download it?
>> > >> >>> > Virginia
>> > >> >>> Yes, you can. Follow this post's instructions:
>> > >> >>> http://gis4free.wordpress.com/2011/03/10/how-to-install-and-
>> > configure-postgis-raster-on-windows/
>> > >> >>> Best regards,
>> > >> >>> Jorge
>> > >> >>> >> Hi,
>> > >> >>> >> The mode=2 parameter is only valid with the last version of
>> > >> >>> >> GDAL
>> > >> >>> >> (1.8.0). So, as Regina said, you need that version to make it
>> > >> >>> >> work
>> > >> >>> >> properly. More accurately:
>> > >> >>> >> - With a GDAL version down to 1.7.1, you can't make it work
in
>> > >> >>> >> any
>> > >> >>> >> way. No driver.
>> > >> >>> >> - With a GDAL version between 1.7.1 and 1.7.3, both included,
>> > >> >>> >> you
>> > >> >>> >> can
>> > >> >>> >> use the old version of the driver, thought to work with the
>> > >> >>> >> old
>> > >> >>> >> wktraster extension, now abandoned. And it was buggy. Not
>> > >> >>> >> recommended.
>> > >> >>> >>  Neither GDAL 1.7.x nor wktraster.
>> > >> >>> >> - With GDAL version up to 1.8.0, you can use the last version
>> > >> >>> >> of
>> > >> >>> >> GDAL
>> > >> >>> >> PostGIS Raster driver, and you'll need PostGIS 2.0, that
>> > >> >>> >> includes
>> > >> >>> >> PostGIS Raster extension. Additionally, as Regina said, those
>> > >> >>> >> days
>> > >> >>> >> we're working on the driver, and all the improvements will be
>> > >> >>> >> included
>> > >> >>> >> in GDAL 1.8.x
>> > >> >>> >> So, summarizing: You need PostGIS 2.0 plus GDAL 1.8.0 to make
>> > >> >>> >> it
>> > >> >>> >> work.
>> > >> >>> >> Further information on the driver:
>> > >> >>> >> http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html
>> > >> >>> >> Best regards,
>> > >> >>> >> Jorge
>> > >> >>> >> On Thu, Jun 2, 2011 at 6:53 AM, Paragon Corporation
>> > >> >>> >> <lr at pcorp.us>
>> > >> >>> >> wrote:
>> > >> >>> >> > Virginia,
>> > >> >>> >> > I think you are missing a mode='2'  in your connection.
>> > >> >>> >> > That was
>> > >> >>> >> > a
>> > >> >>> >> > new
>> > >> >>> >> > requirement that was added for GDAL 1.8+
>> > >> >>> >> > Try putting that in.  I think the speed on the loading
still
>> > >> >>> >> > needs
>> > >> >>> >> > quite
>> > >> >>> >> > a
>> > >> >>> >> > bit of work though last I tried.  The speed issues will
>> > >> >>> >> > hopefully
>> > >> >>> >> > be
>> > >> >>> >> > resolved before 2.0 release.
>> > >> >>> >> > Thanks,
>> > >> >>> >> > Regina
>> > >> >>> >> > ________________________________
>> > >> >>> >> > Behalf
>> > >> >>> >> > Of
>> > >> >>> >> > Virginia
>> > >> >>> >> > Maffei
>> > >> >>> >> > Sent: Wednesday, June 01, 2011 8:00 PM
>> > >> >>> >> > To: postgis-users at postgis.refractions.net
>> > >> >>> >> > Subject: [postgis-users] Mapserver connection to Postgis
>> > >> >>> >> > Raster
>> > >> >>> >> > Hi, i'm new at this and i'm trying to connect to postgis
>> > >> >>> >> > raster
>> > >> >>> >> > in
>> > >> >>> >> > the
>> > >> >>> >> > mapfile.
>> > >> >>> >> > I loaded a tif file into postgis raster database with the
>> > >> >>> >> > raster2pgsql.py
>> > >> >>> >> > script. It created a table with 2 fields: rid and rast.
>> > >> >>> >> > In the mapfile i added the connection like it specifies in
>> > >> >>> >> > the
>> > >> >>> >> > postgis
>> > >> >>> >> > raster FAQ but it doesn't displays anything.
>> > >> >>> >> > This is my mapfile:
>> > >> >>> >> > MAP
>> > >> >>> >> >   IMAGETYPE      PNG24
>> > >> >>> >> >   EXTENT         366582.2901411663 6127927.100382689
>> > >> >>> >> > 857582.2901411663
>> > >> >>> >> > 6670927.100382689
>> > >> >>> >> >   SIZE           491 543
>> > >> >>> >> >   SHAPEPATH      "../data"
>> > >> >>> >> >   LAYER # MODIS raster layer begins here
>> > >> >>> >> >     NAME         modis
>> > >> >>> >> > TYPE         RASTER
>> > >> >>> >> > STATUS       ON
>> > >> >>> >> > DATA "PG:host=localhost port=5432 dbname='postgis'
>> > >> >>> >> > user='postgres'
>> > >> >>> >> > password='postgres' schema='public'
>> > >> >>> >> > table='HumedadDeExtincion'"
>> > >> >>> >> >     PROCESSING "NODATA=0"
>> > >> >>> >> > PROCESSING "SCALE=AUTO"
>> > >> >>> >> > PROCESSING "SCALE_BUCKETS=201"
>> > >> >>> >> >     PROCESSING   "BANDS=1"
>> > >> >>> >> >     OFFSITE      71 74 65
>> > >> >>> >> > CLASS
>> > >> >>> >> > NAME "red"
>> > >> >>> >> > EXPRESSION ([pixel] < 10)
>> > >> >>> >> > COLOR 255 0 0
>> > >> >>> >> > END
>> > >> >>> >> > CLASS
>> > >> >>> >> > NAME "green"
>> > >> >>> >> > EXPRESSION ([pixel] >= 10 AND [pixel] < 15000 )
>> > >> >>> >> > COLOR 0 255 0
>> > >> >>> >> > END
>> > >> >>> >> > CLASS
>> > >> >>> >> > NAME "blue"
>> > >> >>> >> > EXPRESSION ([pixel] >= 15000 )
>> > >> >>> >> > COLOR 0 255 0
>> > >> >>> >> > END
>> > >> >>> >> >   END # MODIS raster layer ends here
>> > >> >>> >> >   # End of LAYER DEFINITIONS
>> > >> >>> >> > END # All map files must come to an end just as all other
>> > >> >>> >> > things
>> > >> >>> >> > must
>> > >> >>> >> > come
>> > >> >>> >> > to...
>> > >> >>> >> > I have gdal 1.6 , postgis 1.5 and ms4w with mapserver 5.6.6
>> > >> >>> >> > We cant see the tiff file on the browser, it only appears a
>> > >> >>> >> > white
>> > >> >>> >> > image.
>> > >> >>> >> > We did try with the tif without the database connection an
>> > >> >>> >> > it
>> > >> >>> >> > works.
>> > >> >>> >> > Could you help us?
>> > >> >>> >> > Thank you
>> > >> >>> >> > _______________________________________________
>> > >> >>> >> > postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
>> > >> >>> >> Jorge Arévalo
>> > >> >>> >> Internet & Mobilty Division, DEIMOS
>> > >> >>> >> http://es.linkedin.com/in/jorgearevalo80
>> > >> >>> >> http://mobility.grupodeimos.com/
>> > >> >>> >> http://geohash.org/ezjqgrgzz0g
>> > >> >>> Jorge Arévalo
>> > >> Jorge Arévalo
>> > Jorge Arévalo
Jorge Arévalo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110606/63243e43/attachment.html>
