[postgis-users] Mapserver connection to Postgis Raster
Virginia Maffei
vmaffei at gmail.com
Tue Jun 7 06:21:39 PDT 2011
Perfect!! that was the issue!
I changed the table name to lower case when I generated the sql with python
and it worked the gdal_translate and the connection from mapserver!!
Thank you very much!!
Virginia
On Mon, Jun 6, 2011 at 10:24 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Virginia,
> Looking at what you have here. I think what Leo was thinking was right.
> Your table is mixed case. When you put it in gdal_translate without
> quoting, it becomes lower case so can't find the table.
> It's best to just lowercase your tables in the database as he had
> suggestedin the prior email. It will save you a great deal of grief in the
> future. As you have it currently you will always have to
> quote "HumedadDeExtinction"
> Hope that helps,
> Regina and Leo,
> http://www.postgis.us
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Virginia
> Maffei
> *Sent:* Monday, June 06, 2011 9:06 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Mapserver connection to Postgis Raster
> I attached the sql.
> I hope this could help to
> find out whats happening.
> This is what raster_columns has:
> "r_table_catalog";"r_table_schema";"r_table_name";"r_column";"srid";"pixel_types";"out_db";"regular_blocking";"nodata_values";"scale_x";"scale_y";"blocksize_x";"blocksize_y";"extent"
> "";"public";"HumedadDeExtincion";"rast";-1;"{64BF}";f;f;"";1000;-1000;;;""
> thanks!
> Virginia
> 2011/6/6 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> Hi,
>> No, the driver doesn't need an empty entry in raster_columns table. It
>> only checks for raster_columns' existence. This is one of the things
>> I'm going to delete from the driver's code.
>> Virginia, raster_columns table is used in PostGIS Raster extension, to
>> store metadata, but the driver doesn't use it. I don't think that's
>> the problem. Could you send me the SQL code for your raster table? The
>> code generated by raster2pgsql script.
>> Best regards,
>> Jorge
>> On Mon, Jun 6, 2011 at 4:14 PM, Virginia Maffei <vmaffei at gmail.com>
>> wrote:
>> > Sorry but i didn't understand very well. In the raster_columns table i
>> have
>> > an entry for this table.
>> > I dont now if i'm answering you question.
>> > Virginia
>> > On Mon, Jun 6, 2011 at 10:54 AM, Pierre Racine <
>> Pierre.Racine at sbf.ulaval.ca>
>> > wrote:
>> >> Would it be possible that the driver needs a missing entry in the
>> >> raster_columns table?
>> >> > -----Original Message-----
>> >> > From: postgis-users-bounces at postgis.refractions.net
>> >> > [mailto:postgis-users-
>> >> > bounces at postgis.refractions.net] On Behalf Of Jorge Arévalo
>> >> > Sent: Monday, June 06, 2011 4:01 AM
>> >> > To: PostGIS Users Discussion
>> >> > Subject: Re: [postgis-users] Mapserver connection to Postgis Raster
>> >> > Hi,
>> >> > Did you test using single quotes surrounding at least the table name?
>> >> > The blank spaces may cause problems.
>> >> > Best regards,
>> >> > Jorge
>> >> > On Sun, Jun 5, 2011 at 11:03 PM, Virginia Maffei <vmaffei at gmail.com>
>> >> > wrote:
>> >> > > Hi, I installed again de postgis 2.0 and now i could load al the
>> .sql
>> >> > > with the makepostgisdb.bat that de windows version brings. The only
>> >> > > thing is that i had to first create de DB and then in a separate
>> .bat
>> >> > > run the .sql
>> >> > load.
>> >> > > I installed gdal 1.8 and also have de gdal 1.8 in the mapserver
>> (ms4w
>> >> > > 3.0.2) installation, but i cant connect with the data base i'm
>> trying
>> >> > > to run a gdal_translate or gdal_info and it doesnt work. I created
>> a
>> >> > > new data base having as template the one loaded with the postgis
>> 2.0
>> >> > > This is the error that it shows:
>> >> > > C:\ms4w\tools\gdal-ogr>gdal_translate PG:"dbname=raster
>> user=postgres
>> >> > > table=Hume dadDeExtincion mode=2"
>> >> > > C:\TSIG\capas\sql2\HumedadDeExtincion.tif
>> >> > > ERROR 1: Error browsing database for PostGIS Raster properties
>> >> > > GDALOpen failed - 1 Error browsing database for PostGIS Raster
>> >> > > properties
>> >> > > Any way...i will post this problem in another thread because the
>> >> > > subject is different.
>> >> > > regards,
>> >> > > Virginia
>> >> > > 2011/6/3 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> >> > >> [SP] Hola Virginia. Realmente el único español, que yo sepa, soy
>> yo,
>> >> > >> así que si no te importa, voy a responder a tu pregunta en inglés
>> >> > >> [EN] Hi Virginia, AFAIK, I'm the only Spanish on the list. So, I'm
>> >> > >> going to answer your question in english.
>> >> > >> Are you sure you loaded all the needed sql files? These are
>> >> > >> postgis.sql, spatial_ref_sys.sql and rtpostgis.sql
>> >> > >> Best regards,
>> >> > >> Jorge
>> >> > >> On Thu, Jun 2, 2011 at 11:36 PM, Virginia Maffei <
>> >> > >> wrote:
>> >> > >> > Hola! estoy intentando cargar manualmente el raster support y
>> estoy
>> >> > >> > ejecutando el rtpostgissql que trae el postgis2.0 Pero al
>> >> > >> > ejecutarlo me tira que no existe la funcion box2d(raster) Alguna
>> >> > >> > idea de que puede estar pasando?
>> >> > >> > Gracias!
>> >> > >> > PD: Escribí en español porque me pareció ver que son de españa y
>> yo
>> >> > >> > en realidad hablo en español.
>> >> > >> > saludos!
>> >> > >> > Virginia
>> >> > >> > On Thu, Jun 2, 2011 at 11:16 AM, Virginia Maffei
>> >> > >> > wrote:
>> >> > >> >> Thank you!! I will try that installation Virginia
>> >> > >> >> 2011/6/2 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> >> > >> >>> On Thu, Jun 2, 2011 at 3:25 PM, Virginia Maffei
>> >> > >> >>> wrote:
>> >> > >> >>> > Thank you for your quick response!
>> >> > >> >>> > I have another question: can i install postgis 2.0 in
>> windows?
>> >> > >> >>> > where
>> >> > >> >>> > can I
>> >> > >> >>> > download it?
>> >> > >> >>> > Virginia
>> >> > >> >>> Yes, you can. Follow this post's instructions:
>> >> > >> >>> http://gis4free.wordpress.com/2011/03/10/how-to-install-and-
>> >> > configure-postgis-raster-on-windows/
>> >> > >> >>> Best regards,
>> >> > >> >>> Jorge
>> >> > >> >>> >> Hi,
>> >> > >> >>> >> The mode=2 parameter is only valid with the last version of
>> >> > >> >>> >> GDAL
>> >> > >> >>> >> (1.8.0). So, as Regina said, you need that version to make
>> it
>> >> > >> >>> >> work
>> >> > >> >>> >> properly. More accurately:
>> >> > >> >>> >> - With a GDAL version down to 1.7.1, you can't make it work
>> in
>> >> > >> >>> >> any
>> >> > >> >>> >> way. No driver.
>> >> > >> >>> >> - With a GDAL version between 1.7.1 and 1.7.3, both
>> included,
>> >> > >> >>> >> you
>> >> > >> >>> >> can
>> >> > >> >>> >> use the old version of the driver, thought to work with the
>> >> > >> >>> >> old
>> >> > >> >>> >> wktraster extension, now abandoned. And it was buggy. Not
>> >> > >> >>> >> recommended.
>> >> > >> >>> >> Neither GDAL 1.7.x nor wktraster.
>> >> > >> >>> >> - With GDAL version up to 1.8.0, you can use the last
>> version
>> >> > >> >>> >> of
>> >> > >> >>> >> GDAL
>> >> > >> >>> >> PostGIS Raster driver, and you'll need PostGIS 2.0, that
>> >> > >> >>> >> includes
>> >> > >> >>> >> PostGIS Raster extension. Additionally, as Regina said,
>> those
>> >> > >> >>> >> days
>> >> > >> >>> >> we're working on the driver, and all the improvements will
>> be
>> >> > >> >>> >> included
>> >> > >> >>> >> in GDAL 1.8.x
>> >> > >> >>> >> So, summarizing: You need PostGIS 2.0 plus GDAL 1.8.0 to
>> make
>> >> > >> >>> >> it
>> >> > >> >>> >> work.
>> >> > >> >>> >> Further information on the driver:
>> >> > >> >>> >> http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html
>> >> > >> >>> >> Best regards,
>> >> > >> >>> >> Jorge
>> >> > >> >>> >> On Thu, Jun 2, 2011 at 6:53 AM, Paragon Corporation
>> >> > >> >>> >> <lr at pcorp.us>
>> >> > >> >>> >> wrote:
>> >> > >> >>> >> > Virginia,
>> >> > >> >>> >> > I think you are missing a mode='2' in your connection.
>> >> > >> >>> >> > That was
>> >> > >> >>> >> > a
>> >> > >> >>> >> > new
>> >> > >> >>> >> > requirement that was added for GDAL 1.8+
>> >> > >> >>> >> > Try putting that in. I think the speed on the loading
>> still
>> >> > >> >>> >> > needs
>> >> > >> >>> >> > quite
>> >> > >> >>> >> > a
>> >> > >> >>> >> > bit of work though last I tried. The speed issues will
>> >> > >> >>> >> > hopefully
>> >> > >> >>> >> > be
>> >> > >> >>> >> > resolved before 2.0 release.
>> >> > >> >>> >> > Thanks,
>> >> > >> >>> >> > Regina
>> >> > >> >>> >> > ________________________________
>> >> > >> >>> >> > [mailto:postgis-users-bounces at postgis.refractions.net]
>> On
>> >> > >> >>> >> > Behalf
>> >> > >> >>> >> > Of
>> >> > >> >>> >> > Virginia
>> >> > >> >>> >> > Maffei
>> >> > >> >>> >> > Sent: Wednesday, June 01, 2011 8:00 PM
>> >> > >> >>> >> > To: postgis-users at postgis.refractions.net
>> >> > >> >>> >> > Subject: [postgis-users] Mapserver connection to Postgis
>> >> > >> >>> >> > Raster
>> >> > >> >>> >> > Hi, i'm new at this and i'm trying to connect to postgis
>> >> > >> >>> >> > raster
>> >> > >> >>> >> > in
>> >> > >> >>> >> > the
>> >> > >> >>> >> > mapfile.
>> >> > >> >>> >> > I loaded a tif file into postgis raster database with the
>> >> > >> >>> >> > raster2pgsql.py
>> >> > >> >>> >> > script. It created a table with 2 fields: rid and rast.
>> >> > >> >>> >> > In the mapfile i added the connection like it specifies
>> in
>> >> > >> >>> >> > the
>> >> > >> >>> >> > postgis
>> >> > >> >>> >> > raster FAQ but it doesn't displays anything.
>> >> > >> >>> >> > This is my mapfile:
>> >> > >> >>> >> > MAP
>> >> > >> >>> >> > IMAGETYPE PNG24
>> >> > >> >>> >> > EXTENT 366582.2901411663 6127927.100382689
>> >> > >> >>> >> > 857582.2901411663
>> >> > >> >>> >> > 6670927.100382689
>> >> > >> >>> >> > SIZE 491 543
>> >> > >> >>> >> > SHAPEPATH "../data"
>> >> > >> >>> >> > LAYER # MODIS raster layer begins here
>> >> > >> >>> >> > NAME modis
>> >> > >> >>> >> > TYPE RASTER
>> >> > >> >>> >> > STATUS ON
>> >> > >> >>> >> > DATA "PG:host=localhost port=5432 dbname='postgis'
>> >> > >> >>> >> > user='postgres'
>> >> > >> >>> >> > password='postgres' schema='public'
>> >> > >> >>> >> > table='HumedadDeExtincion'"
>> >> > >> >>> >> > PROCESSING "NODATA=0"
>> >> > >> >>> >> > PROCESSING "SCALE=AUTO"
>> >> > >> >>> >> > PROCESSING "SCALE_BUCKETS=201"
>> >> > >> >>> >> > PROCESSING "BANDS=1"
>> >> > >> >>> >> > OFFSITE 71 74 65
>> >> > >> >>> >> > CLASS
>> >> > >> >>> >> > NAME "red"
>> >> > >> >>> >> > EXPRESSION ([pixel] < 10)
>> >> > >> >>> >> > COLOR 255 0 0
>> >> > >> >>> >> > END
>> >> > >> >>> >> > CLASS
>> >> > >> >>> >> > NAME "green"
>> >> > >> >>> >> > EXPRESSION ([pixel] >= 10 AND [pixel] < 15000 )
>> >> > >> >>> >> > COLOR 0 255 0
>> >> > >> >>> >> > END
>> >> > >> >>> >> > CLASS
>> >> > >> >>> >> > NAME "blue"
>> >> > >> >>> >> > EXPRESSION ([pixel] >= 15000 )
>> >> > >> >>> >> > COLOR 0 255 0
>> >> > >> >>> >> > END
>> >> > >> >>> >> > END # MODIS raster layer ends here
>> >> > >> >>> >> > # End of LAYER DEFINITIONS
>> >> > >> >>> >> > END # All map files must come to an end just as all other
>> >> > >> >>> >> > things
>> >> > >> >>> >> > must
>> >> > >> >>> >> > come
>> >> > >> >>> >> > to...
>> >> > >> >>> >> > I have gdal 1.6 , postgis 1.5 and ms4w
>> with mapserver 5.6.6
>> >> > >> >>> >> > We cant see the tiff file on the browser, it only appears
>> a
>> >> > >> >>> >> > white
>> >> > >> >>> >> > image.
>> >> > >> >>> >> > We did try with the tif without the database connection
>> an
>> >> > >> >>> >> > it
>> >> > >> >>> >> > works.
>> >> > >> >>> >> > Could you help us?
>> >> > >> >>> >> > Thank you
>> >> > >> >>> >> > _______________________________________________
>> >> > >> >>> >> > postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> >> > >> >>> >> Jorge Arévalo
>> >> > >> >>> >> Internet & Mobilty Division, DEIMOS
>> >> > >> >>> >> http://es.linkedin.com/in/jorgearevalo80
>> >> > >> >>> >> http://mobility.grupodeimos.com/
>> >> > >> >>> >> http://geohash.org/ezjqgrgzz0g
>> >> > >> >>> Jorge Arévalo
>> >> > >> Jorge Arévalo
>> >> > Jorge Arévalo
>> Jorge Arévalo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110607/bbdcb1ea/attachment.html>
