[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Magnus Hagander
magnus at hagander.net
Wed Jun 8 11:58:44 PDT 2011
On Tue, May 31, 2011 at 14:06, Magnus Hagander <magnus at hagander.net> wrote:
> On Fri, May 27, 2011 at 21:07, Sandro Santilli <strk at keybit.net> wrote:
>> On Fri, May 27, 2011 at 09:28:57AM -0700, Paul Ramsey wrote:
>>> I'm finding it difficult to have the regression test and also the
>>> NOTICE in isvalid and also have the differential behaviour for
>>> different versions of GEOS. One is going to have to go. I can't
>>> ensure the "reason" I provide in my short circuit to match the reason
>>> GEOS is going to give.
>> What you can do is _not_ using tickets.sql but a dedicated file, maybe
>> bugXXX.sql and bugXXX_pre_geos33.sql, and switch between the two from
>> the Makefile.
> So to be clear on this for someone who's not following the svn repo -
> has a fix for this been applied now?
Hrrm... Ping?
Magnus Hagander
Me: http://www.hagander.net/
Work: http://www.redpill-linpro.com/
