[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Sandro Santilli
strk at keybit.net
Thu Jun 9 03:35:56 PDT 2011
On Wed, Jun 8, 2011 at 8:58 PM, Magnus Hagander <magnus at hagander.net> wrote:
> On Tue, May 31, 2011 at 14:06, Magnus Hagander <magnus at hagander.net> wrote:
>> On Fri, May 27, 2011 at 21:07, Sandro Santilli <strk at keybit.net> wrote:
>>> On Fri, May 27, 2011 at 09:28:57AM -0700, Paul Ramsey wrote:
>>>> I'm finding it difficult to have the regression test and also the
>>>> NOTICE in isvalid and also have the differential behaviour for
>>>> different versions of GEOS. One is going to have to go. I can't
>>>> ensure the "reason" I provide in my short circuit to match the reason
>>>> GEOS is going to give.
>>> What you can do is _not_ using tickets.sql but a dedicated file, maybe
>>> bugXXX.sql and bugXXX_pre_geos33.sql, and switch between the two from
>>> the Makefile.
>> So to be clear on this for someone who's not following the svn repo -
>> has a fix for this been applied now?
> Hrrm... Ping?
The fix is in upgrading GEOS (3.3.0 is out).
If you can upgrade PostGIS you can also upgrade GEOS, right ?
--strk;
Free GIS & Flash consultant/developer
http://strk.keybit.net/services.html
