[postgis-users] QGIS - PostGIS - ArcGIS Interaction
Cristian Olguín Avila
cristianolguin at gmail.com
Wed Jun 15 11:14:44 PDT 2011
some ideas...
- create a view with name column length as you want.
- looking for software ziggis, with this you can connect arcmap to Postgres
Geodatabase
bye...
Cristian O.
www.digitalbee.cl
On Wed, Jun 15, 2011 at 1:58 PM, James David Smith <
james.david.smith at gmail.com> wrote:
> Dear all,
> I appreciate that this is more of a QGIS query, but I think that the
> route of the problem might be in PostGIS, so... I have opened QGIS and
> ran the query on my PostGIS table as below:
> SELECT * FROM incidents
> WHERE urgency = 'Immediate'
> AND date_time_of_arrival - date_time_unit_assigned > '00:12:00'
> This gives me 33 points in QGIS. Great. I would now however like to
> save this as a ShapeFile for use in ArcGIS with which I am more
> familiar, but when I try to SAVE AS from QGIS I am given the following
> error....
> Export to vector file failed.
> Error: trimming attribute name 'date_time_of_arrival' to ten
> significant characters produces duplicate column name.
> I am guessing that the problem here is that ESRI shapefiles can only
> deal with column names that are ten characters long...? And that as I
> also have a column called 'date_time_of_departure', when QGIS trims
> this column it ends up with two columns called the same thing? Is
> there a way around this? I realise I could rename the column in QGIS,
> but I actually have around 45 columns in the table and this problem
> will occur with about 15 pairs of them I think. I guess there is no
> simple answer... but thought I'd ask.
> Cheers
> James
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110615/5880bcce/attachment.html>
