[postgis-users] QGIS - PostGIS - ArcGIS Interaction
David Fawcett david.fawcett at gmail.com
Wed Jun 15 11:16:47 PDT 2011
This is what is really cool about using a database to store your data...
Change your query to:
SELECT mycol1,
             mycol2,
             date_time_of_arrival as dt_arrive,
             date_time_of_departure as dt_depart,
              the_geom
FROM incidents
WHERE urgency = 'Immediate'
AND date_time_of_arrival - date_time_unit_assigned > '00:12:00'
Note: you will need to specify the names of the columns that you are
interested in.
On Wed, Jun 15, 2011 at 12:58 PM, James David Smith
<james.david.smith at gmail.com> wrote:
> Dear all,
> I appreciate that this is more of a QGIS query, but I think that the
> route of the problem might be in PostGIS, so... I have opened QGIS and
> ran the query on my PostGIS table as below:
> SELECT * FROM incidents
> This gives me 33 points in QGIS. Great. I would now however like to
> save this as a ShapeFile for use in ArcGIS with which I am more
> familiar, but when I try to SAVE AS from QGIS I am given the following
> error....
> Export to vector file failed.
> Error: trimming attribute name 'date_time_of_arrival' to ten
> significant characters produces duplicate column name.
> I am guessing that the problem here is that ESRI shapefiles can only
> deal with column names that are ten characters long...? And that as I
> also have a column called 'date_time_of_departure', when QGIS trims
> this column it ends up with two columns called the same thing?  Is
> there a way around this? I realise I could rename the column in QGIS,
> but I actually have around 45 columns in the table and this problem
> will occur with about 15 pairs of them I think. I guess there is no
> simple answer... but thought I'd ask.
> Cheers
> James
> postgis-users mailing list
