[postgis-users] UpdateGeometrySRID error
Sergio Baños Calvo listas at saig.es
Thu Jun 16 05:43:58 PDT 2011
Hi Andreas.
Try with:
SELECT UpdateGeometrySRID('groads2', 'geom', 4326);
Regards,
El 16/06/2011 10:23, Andreas Forø Tollefsen escribió:
> Hi,
> I have merged 4 tables with line geometry. In total 1028110 rows.
> However, when i had unionized the tables, i realized that i had forgot
> to set the SRID for 2 of the tables.
> Hence, I now have a table where half of the roughly half a million
> rows have a SRID.
> I then tried to run the UpdateGeometrySRID, but something is wrong.
> Syntax seems correct according to manual:
> http://postgis.refractions.net/documentation/manual-svn/UpdateGeometrySRID.html
> <sql>
> SELECT UpdateGeometrySRID(groads2, geom, 4326);
> </sql>
> groads2 is my table, geom is the geometry column and the srid should
> be 4326 WGS84.
> However, when running the above query, i get this:
> ERROR:  column "groads2" does not exist
> LINE 3: SELECT UpdateGeometrySRID(groads2, geom, 4326);
> ********** Error **********
> SQL state: 42703
> Character: 99
> Any ideas?
> postgis-users mailing list
Sergio Baños Calvo
Jefe de desarrollos
Sistemas Abiertos de Información Geográfica, S.L. (SAIG S.L.)
Tlfno. móvil: 685005960
Tlfno. fijo: (+34) 954788876
E-mail: sbc at saig.es
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110616/bc9eceff/attachment.html>
