[postgis-users] UpdateGeometrySRID error
James David Smith james.david.smith at gmail.com
Thu Jun 16 05:21:59 PDT 2011
I'm a novice, but shouldn't it be something like this... ?
UPDATE table SET geom = ST_SetSRID(geom, 4326)
Cheers
James
On 16 June 2011 09:23, Andreas Forø Tollefsen <andreasft at gmail.com> wrote:
> Hi,
> I have merged 4 tables with line geometry. In total 1028110 rows.
> However, when i had unionized the tables, i realized that i had forgot
> to set the SRID for 2 of the tables.
> Hence, I now have a table where half of the roughly half a million
> rows have a SRID.
> I then tried to run the UpdateGeometrySRID, but something is wrong.
> Syntax seems correct according to manual:
> http://postgis.refractions.net/documentation/manual-svn/UpdateGeometrySRID.html
> <sql>
> SELECT UpdateGeometrySRID(groads2, geom, 4326);
> </sql>
> groads2 is my table, geom is the geometry column and the srid should
> be 4326 WGS84.
> However, when running the above query, i get this:
> ERROR:  column "groads2" does not exist
> LINE 3: SELECT UpdateGeometrySRID(groads2, geom, 4326);
> ********** Error **********
> SQL state: 42703
> Character: 99
> Any ideas?
> postgis-users mailing list
