[postgis-users] Problem with ST_intersects
James Sewell James.Sewell at lisasoft.com
Tue Jun 21 17:58:39 PDT 2011
Upgraded on CentOS to
  POSTGIS="1.5.3SVN" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.6.26" USE_STATS
And the problem still occurs:
  plm25new=>  select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id =1954;
    id  | st_intersects
   1954 | t
  (1 row)
  plm25new=>  select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id = 2034 or a.id =1954;
    id  | st_intersects
   2034 | t
   1954 | f
  (2 rows)
The problem does not occur with ST_Relate:
plm25new=>  select  a.id, ST_relate(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id = 2034 or a.id =1954;
    id  | st_relate
   2034 | 0FFFFF212
   1954 | 0FFFFF212
  (2 rows)
Also it does not seem to occur if I make the point into a tiny polygon:
plm25new=>  select  a.id, ST_intersects(st_buffer(a.the_geom,10e-8), b.the_geom) from apoly as a, aright as b
  id  | st_intersects
 2034 | t
 1954 | t
(2 rows)
In fact I have just noticed I can cause all sorts of problems by using different where clauses - could it be some sort of caching problem?
  plm25new=>  select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=2034  order by a.id;
   id  | st_intersects
   2034 | t
  (1 row)
  plm25new=>  select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=2033  order by a.id;
    id  | st_intersects
   2033 | t
  (1 row)
  plm25new=>  select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=1954  order by a.id;
    id  | st_intersects
   1954 | t
  (1 row)
  plm25new=>  select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=2033 or id=1954 order by a.id;
    id  | st_intersects
  1954 | t
  2033 | f
  (2 rows)
  plm25new=>  select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=2034 or id=1954 order by a.id;
    id  | st_intersects
   1954 | f
   2034 | t
  (2 rows)
  plm25new=>  select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b order by a.id;
    id  | st_intersects
   1954 | f
   2033 | f
   2034 | t
  (3 rows)
James Sewell
Solutions Architect
Ardec International
Office: (03) 86803200
Mobile: 0414 688 892
________________________________________
From: postgis-users-bounces at postgis.refractions.net [postgis-users-bounces at postgis.refractions.net] On Behalf Of James Sewell [James.Sewell at lisasoft.com]
Sent: Wednesday, 22 June 2011 10:10 AM
To: PostGIS Users Discussion; postgis-dev at postgis.refractions.net
Subject: Re: [postgis-users] Problem with ST_intersects
Aha,
http://trac.osgeo.org/postgis/ticket/845
I will upgrade to 1.5.3 and retest!
James Sewell
Solutions Architect
Ardec International
Sent: Tuesday, 21 June 2011 1:58 PM
Sorry, I forgot to say I have encountered the problem with the following versions / OSes
 CentOS: POSTGIS="1.5.2" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September 2009 " LIBXML="2.6.26" USE_STATS
 Solaris: POSTGIS="1.5.2" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.6.31" USE_STATS
James Sewell
Developer
LISAsoft
Sent: Tuesday, 21 June 2011 1:50 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Problem with ST_intersects
Hello All,
I think I have found a bug. For the data attached the following commands yield interesting results, with the output of ST_intersects seemingly changed by the where clause.
  plm25=> select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id = 1954 or a.id =2034 order by id;
    id  | st_intersects
   1954 | f
   2034 | t
  (2 rows)
  plm25=> select  a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b  where a.id = 1954 or a.id =2033 order by id;
    id  | st_intersects
   1954 | t
   2033 | t
  (2 rows)
Anyone have any ideas why this might be so?
James Sewell
Solutions Architect
Ardec International
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
