[postgis-users] Problem with ST_intersects
James Sewell
James.Sewell at lisasoft.com
Sun Jun 26 20:46:58 PDT 2011
Fixed as of 1.5.3 stable.
Cheers,
James Sewell
Developer
LISAsoft
Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
Level 9, 601 Bourke St, Melbourne Vic 3000
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of James Sewell
Sent: Wednesday, 22 June 2011 10:59 AM
To: PostGIS Users Discussion; postgis-devel at postgis.refractions.net
Subject: Re: [postgis-users] Problem with ST_intersects
Upgraded on CentOS to
POSTGIS="1.5.3SVN" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.6.26" USE_STATS
And the problem still occurs:
plm25new=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id =1954;
id | st_intersects
1954 | t
(1 row)
plm25new=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id = 2034 or a.id =1954;
id | st_intersects
2034 | t
1954 | f
(2 rows)
The problem does not occur with ST_Relate:
plm25new=> select a.id, ST_relate(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id = 2034 or a.id =1954;
id | st_relate
2034 | 0FFFFF212
1954 | 0FFFFF212
(2 rows)
Also it does not seem to occur if I make the point into a tiny polygon:
plm25new=> select a.id, ST_intersects(st_buffer(a.the_geom,10e-8), b.the_geom) from apoly as a, aright as b
id | st_intersects
2034 | t
1954 | t
(2 rows)
In fact I have just noticed I can cause all sorts of problems by using different where clauses - could it be some sort of caching problem?
plm25new=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=2034 order by a.id;
id | st_intersects
2034 | t
(1 row)
plm25new=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=2033 order by a.id;
id | st_intersects
2033 | t
(1 row)
plm25new=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=1954 order by a.id;
id | st_intersects
1954 | t
(1 row)
plm25new=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=2033 or id=1954 order by a.id;
id | st_intersects
1954 | t
2033 | f
(2 rows)
plm25new=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where id=2034 or id=1954 order by a.id;
id | st_intersects
1954 | f
2034 | t
(2 rows)
plm25new=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b order by a.id;
id | st_intersects
1954 | f
2033 | f
2034 | t
(3 rows)
James Sewell
Solutions Architect
Ardec International
Office: (03) 86803200
Mobile: 0414 688 892
________________________________________
From: postgis-users-bounces at postgis.refractions.net [postgis-users-bounces at postgis.refractions.net] On Behalf Of James Sewell [James.Sewell at lisasoft.com]
Sent: Wednesday, 22 June 2011 10:10 AM
To: PostGIS Users Discussion; postgis-dev at postgis.refractions.net
Aha,
http://trac.osgeo.org/postgis/ticket/845
I will upgrade to 1.5.3 and retest!
James Sewell
Solutions Architect
Ardec International
Sent: Tuesday, 21 June 2011 1:58 PM
Sorry, I forgot to say I have encountered the problem with the following versions / OSes
CentOS: POSTGIS="1.5.2" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September 2009 " LIBXML="2.6.26" USE_STATS
Solaris: POSTGIS="1.5.2" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.6.31" USE_STATS
James Sewell
Developer
LISAsoft
Sent: Tuesday, 21 June 2011 1:50 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Problem with ST_intersects
Hello All,
I think I have found a bug. For the data attached the following commands yield interesting results, with the output of ST_intersects seemingly changed by the where clause.
plm25=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id = 1954 or a.id =2034 order by id;
id | st_intersects
1954 | f
2034 | t
(2 rows)
plm25=> select a.id, ST_intersects(a.the_geom, b.the_geom) from apoly as a, aright as b where a.id = 1954 or a.id =2033 order by id;
id | st_intersects
1954 | t
2033 | t
(2 rows)
Anyone have any ideas why this might be so?
James Sewell
Solutions Architect
Ardec International
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
