[postgis-users] How to Store Metadata?
Nicolas Ribot nicolas.ribot at gmail.com
Fri Jun 24 07:46:31 PDT 2011
On 24 June 2011 15:02, Brett Antonides <bantonid at gmail.com> wrote:
> Hi Everybody,
> Could someone please tell me or send me a link describing how to best store
> ISO 19115/19139 metadata with my spatial data in PostGIS?  Ultimately, the
> data will be stored in PostGIS, published via GeoServer, and cataloged in
> GeoNetwork.  I know I can just load the metadata into GeoNetwork, but I'd
> rather store it in the database so it doesn't get lost if data is migrated
> to another server.  I'm hoping someone has already cracked this nut.  I
> tried searching for the answer, but Google failed me (or I failed Google).
>  Either way I'd appreciate any help you can provide.
> Brett
I'm not sure to fully understand your question:
Geonetwork is able to use a Postgresql database as backend, so storing
metadata can occur in the same database as data are.
Nicolas
