[postgis-users] Tiger Geocoder 2010 setup issues
Daniel Weitzenfeld
dweitzenfeld at gmail.com
Tue Jun 28 03:51:06 PDT 2011
I'm trying to setup the TIGER Geocoder, following the readme here:
http://svn.osgeo.org/postgis/trunk/extras/tiger_geocoder/tiger_2010/README
I'm setting it up on a centos 5.5 server.
My questions are below, organized by the step in the README.
------| Step 3. Edit the tiger_loader.sql to the paths of your
executables server etc.
Is the UNZIPTOOL variable supposed to be changed, or left at its default?
UNZIPTOOL=unzip
------| Step 4. Edit the create_geocode.bat or create_geocode.sh and run
When I ran the file, I got a boatload of NOTICEs like the following,
interspersed throughout the output:
psql:tables/lookup_tables_2010.sql:4: NOTICE: table
"direction_lookup" does not exist, skipping
psql:tables/lookup_tables_2010.sql:39: NOTICE: table
"secondary_unit_lookup" does not exist, skipping
Is this something I should be concerned about? Did I skip something?
Perhaps more alarmingly, the output finished with this:
COMMIT
ERROR: relation "addr" does not exist
Again, what should I do?
------| 8. Run this command at psql or pgAdmin III query window to
generate the script.
The first line of the generated script doesn't look right:
STATEDIR="/gisdata/www2.census.gov/geo/pvs/tiger2010st/36_New_York"
especially because an early command is
cd $STATEDIR
Also, when I try to run the generated script anyway, I get a boatload of these:
psql: FATAL: Ident authentication failed for user "daniel"
...which is strange to me because I user I thought user daniel had
rights on the PGDATABASE. Indeed, user daniel can create/delete
schemas on it. Am I misunderstanding something about postgres
permissions?
Thanks in advance for any guidance you can provide.
Best,
-Daniel
