[postgis-users] PostGIS query layer in ArcMap - Double values looklike integers
Robert_Clift at doh.state.fl.us
Tue Jun 28 13:06:16 PDT 2011
Could it be the Rounding settings in the Number Format dialog? You can
access the Number Format dialog by clicking the [...] to the right of
the word "Numeric" in the Field Properties dialog.
-Rob
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sheara Cohen
Sent: Tuesday, June 28, 2011 3:17 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostGIS query layer in ArcMap - Double values
looklike integers
Does anyone know why the values in a double field would appear like
integers when a PostGIS file is viewed as a query layer in ArcMap?
In other words, I've added a PostGIS table as a query layer to ArcMap,
and when I open the attribute table, several fields only have integer
values (no decimal places) even though you can check the properties of
those fields and verify that they are indeed double. When the same table
is viewed in PGAdmin the values display with all their appropriate
decimal places.
What gives?
Thank you.
Sheara
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110628/8270d34c/attachment.html>
