[postgis-users] Raster2pgsql.py Possible No Data Problem
Andreas Forø Tollefsen
andreasft at gmail.com
Thu Mar 3 01:26:06 PST 2011
Very strange. The out of memory error i posted in my last post i got on my
64 bit desktop. I tried the excact same thing on my 32 bit laptop, and there
i did not get a out of memory when importing to the postgis1.5 database.
Andreas
2011/3/3 Andreas Forø Tollefsen <andreasft at gmail.com>
> It seems I had some problems with my gdal python bindings. I downloaded the
> 64 bit Python 2.6 GDAL 1.7 bindings from here
> http://www.lfd.uci.edu/~gohlke/pythonlibs/.
> Now i can create the sql file. However. I have some new problems when
> importing.
> It works when i try to write the sql file to my PostGIS 2.0 database, but
> not to my PostGIS 1.5 database.
> See errors below (first is 1.5, second is 2.0 and working):
> C:\prio_grid\source\mountain>psql -h localhost -U postgres -d newpg -f
> mountain.
> sql
> BEGIN
> psql:mountain.sql:2: NOTICE: CREATE TABLE will create implicit sequence
> "mounta
> in_rid_seq" for serial column "mountain.rid"
> psql:mountain.sql:2: NOTICE: CREATE TABLE / PRIMARY KEY will create
> implicit in
> dex "mountain_pkey" for table "mountain"
> CREATE TABLE
> addrastercolumn
> public.mountain.rast srid:4326 pixel_types:{32BF} out_db:false
> regular_blocking
> :false nodata_values:'{-3.40282346639e+038}' pixelsize_x:'0.08333334'
> pixelsize_
> y:'-0.08333334' blocksize_x:NULL blocksize_y:NULL extent:NULL
> (1 row)
> psql:mountain.sql:4: ERROR: out of memory
> DETAIL: Failed on request of size 134217728.
> psql:mountain.sql:5: ERROR: current transaction is aborted, commands
> ignored un
> til end of transaction block
> ROLLBACK
> template_postgis20
> -f mountain.sql
> BEGIN
> "mounta
> implicit in
> CREATE TABLE
> addrastercolumn
> regular_blocking
> :false nodata_values:'{-3.40282346639e+038}' scale_x:'0.08333334'
> scale_y:'-0.08
> (1 row)
> INSERT 0 1
> CREATE INDEX
> COMMIT
> 2011/3/2 Andreas Forø Tollefsen <andreasft at gmail.com>
> Hi. Sorry. I was confused and used the Python 2.5.
>> Now i get some other errors when using python 2.6. Could it be my setup
>> which is not correct?
>> C:\Python26>python raster2pgsql.py -r
>> c:\prio_grid\source\mountain\mean_mnt_bin.
>> tif -t mountain -s 4326 -I -o mountain.sql
>> Traceback (most recent call last):
>> File "raster2pgsql.py", line 1036, in <module>
>> main()
>> File "raster2pgsql.py", line 999, in main
>> gt = wkblify_raster(opts, filename.replace( '\\', '/') , i, gt)
>> File "raster2pgsql.py", line 941, in wkblify_raster
>> summary = wkblify_raster_level(options, ds, options.overview_level,
>> band_ran
>> ge, infile, i)
>> File "raster2pgsql.py", line 901, in wkblify_raster_level
>> hexwkb += wkblify_band(options, band, level, xoff, yoff,
>> read_block_size, bl
>> ock_size, infile, b)
>> File "raster2pgsql.py", line 790, in wkblify_band
>> target_block_size[0], target_block_size[1])
>> File "C:\Python26\Lib\site-packages\osgeo\gdal.py", line 978, in
>> ReadAsArray
>> import gdalnumeric
>> File "C:\Python26\Lib\site-packages\osgeo\gdalnumeric.py", line 1, in
>> <module>
>> from gdal_array import *
>> File "C:\Python26\Lib\site-packages\osgeo\gdal_array.py", line 24, in
>> <module>
>> _gdal_array = swig_import_helper()
>> File "C:\Python26\Lib\site-packages\osgeo\gdal_array.py", line 23, in
>> swig_imp
>> ort_helper
>> return _mod
>> UnboundLocalError: local variable '_mod' referenced before assignment
>> C:\Python26>
>> 2011/3/2 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> On Wed, Mar 2, 2011 at 5:40 PM, Andreas Forø Tollefsen
>>> <andreasft at gmail.com> wrote:
>>> > Hi,
>>> > Postgresql 8.4.7
>>> > postgis-pg84-binaries-2.0.0svn.zip
>>> > Tested with latest raster2pgsql.py rev 6860
>>> > I have a raster which is giving me problems when creating the raster
>>> table.
>>> > The raster does not have any digits for no data but 'no data'.
>>> > Could this be the cause of the below problem? I tried a different
>>> raster
>>> > which normally have been working with the old gdal2wktraster.py script.
>>> > Any suggestions?
>>> > The error:
>>> > C:\Python25>python raster2pgsql.py -r
>>> > tif -t mountain -o mountain.sql
>>> > main()
>>> > band_ran
>>> > ge, infile, i)
>>> > File "raster2pgsql.py", line 853, in wkblify_raster_level
>>> > nodata_values = collect_nodata_values(ds, band_from, band_to)
>>> > File "raster2pgsql.py", line 532, in collect_nodata_values
>>> > if nodata is not None and not math.isnan(nodata):
>>> > AttributeError: 'module' object has no attribute 'isnan'
>>> > C:\Python25>
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > postgis-users at postgis.refractions.net
>>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Hi,
>>> The problem is with the 'isnan' function. I see it was included in
>>> Python 2.6. We need a replacement in case of lower Python versions.
>>> I'll fix it asap (hopefully, when I arrive home).
>>> Best regards, and thanks for the feedback
>>> Jorge Arévalo
>>> Internet & Mobilty Division, DEIMOS
>>> http://es.linkedin.com/in/jorgearevalo80
>>> http://mobility.grupodeimos.com/
>>> http://gis4free.wordpress.com
>>> http://geohash.org/ezjqgrgzz0g
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110303/8cc02b13/attachment.html>
