[postgis-users] Raster2pgsql.py Possible No Data Problem
Andreas Forø Tollefsen
andreasft at gmail.com
Thu Mar 3 00:14:23 PST 2011
It seems I had some problems with my gdal python bindings. I downloaded the
64 bit Python 2.6 GDAL 1.7 bindings from here
http://www.lfd.uci.edu/~gohlke/pythonlibs/.
Now i can create the sql file. However. I have some new problems when
importing.
It works when i try to write the sql file to my PostGIS 2.0 database, but
not to my PostGIS 1.5 database.
See errors below (first is 1.5, second is 2.0 and working):
C:\prio_grid\source\mountain>psql -h localhost -U postgres -d newpg -f
mountain.
sql
BEGIN
psql:mountain.sql:2: NOTICE: CREATE TABLE will create implicit sequence
"mounta
in_rid_seq" for serial column "mountain.rid"
psql:mountain.sql:2: NOTICE: CREATE TABLE / PRIMARY KEY will create
implicit in
dex "mountain_pkey" for table "mountain"
CREATE TABLE
addrastercolumn
public.mountain.rast srid:4326 pixel_types:{32BF} out_db:false
regular_blocking
:false nodata_values:'{-3.40282346639e+038}' pixelsize_x:'0.08333334'
pixelsize_
y:'-0.08333334' blocksize_x:NULL blocksize_y:NULL extent:NULL
(1 row)
psql:mountain.sql:4: ERROR: out of memory
DETAIL: Failed on request of size 134217728.
psql:mountain.sql:5: ERROR: current transaction is aborted, commands
ignored un
til end of transaction block
ROLLBACK
template_postgis20
-f mountain.sql
BEGIN
"mounta
implicit in
CREATE TABLE
addrastercolumn
regular_blocking
:false nodata_values:'{-3.40282346639e+038}' scale_x:'0.08333334'
scale_y:'-0.08
(1 row)
INSERT 0 1
CREATE INDEX
COMMIT
2011/3/2 Andreas Forø Tollefsen <andreasft at gmail.com>
> Hi. Sorry. I was confused and used the Python 2.5.
> Now i get some other errors when using python 2.6. Could it be my setup
> which is not correct?
> C:\Python26>python raster2pgsql.py -r
> c:\prio_grid\source\mountain\mean_mnt_bin.
> tif -t mountain -s 4326 -I -o mountain.sql
> Traceback (most recent call last):
> File "raster2pgsql.py", line 1036, in <module>
> main()
> File "raster2pgsql.py", line 999, in main
> gt = wkblify_raster(opts, filename.replace( '\\', '/') , i, gt)
> File "raster2pgsql.py", line 941, in wkblify_raster
> summary = wkblify_raster_level(options, ds, options.overview_level,
> band_ran
> ge, infile, i)
> File "raster2pgsql.py", line 901, in wkblify_raster_level
> hexwkb += wkblify_band(options, band, level, xoff, yoff,
> read_block_size, bl
> ock_size, infile, b)
> File "raster2pgsql.py", line 790, in wkblify_band
> target_block_size[0], target_block_size[1])
> File "C:\Python26\Lib\site-packages\osgeo\gdal.py", line 978, in
> ReadAsArray
> import gdalnumeric
> File "C:\Python26\Lib\site-packages\osgeo\gdalnumeric.py", line 1, in
> <module>
> from gdal_array import *
> File "C:\Python26\Lib\site-packages\osgeo\gdal_array.py", line 24, in
> <module>
> _gdal_array = swig_import_helper()
> File "C:\Python26\Lib\site-packages\osgeo\gdal_array.py", line 23, in
> swig_imp
> ort_helper
> return _mod
> UnboundLocalError: local variable '_mod' referenced before assignment
> C:\Python26>
> 2011/3/2 Jorge Arévalo <jorge.arevalo at deimos-space.com>
> On Wed, Mar 2, 2011 at 5:40 PM, Andreas Forø Tollefsen
>> <andreasft at gmail.com> wrote:
>> > Hi,
>> > Postgresql 8.4.7
>> > postgis-pg84-binaries-2.0.0svn.zip
>> > Tested with latest raster2pgsql.py rev 6860
>> > I have a raster which is giving me problems when creating the raster
>> table.
>> > The raster does not have any digits for no data but 'no data'.
>> > Could this be the cause of the below problem? I tried a different raster
>> > which normally have been working with the old gdal2wktraster.py script.
>> > Any suggestions?
>> > The error:
>> > C:\Python25>python raster2pgsql.py -r
>> > tif -t mountain -o mountain.sql
>> > main()
>> > band_ran
>> > ge, infile, i)
>> > File "raster2pgsql.py", line 853, in wkblify_raster_level
>> > nodata_values = collect_nodata_values(ds, band_from, band_to)
>> > File "raster2pgsql.py", line 532, in collect_nodata_values
>> > if nodata is not None and not math.isnan(nodata):
>> > AttributeError: 'module' object has no attribute 'isnan'
>> > C:\Python25>
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Hi,
>> The problem is with the 'isnan' function. I see it was included in
>> Python 2.6. We need a replacement in case of lower Python versions.
>> I'll fix it asap (hopefully, when I arrive home).
>> Best regards, and thanks for the feedback
>> Jorge Arévalo
>> Internet & Mobilty Division, DEIMOS
>> http://es.linkedin.com/in/jorgearevalo80
>> http://mobility.grupodeimos.com/
>> http://gis4free.wordpress.com
>> http://geohash.org/ezjqgrgzz0g
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110303/16ea4512/attachment.html>
