[postgis-users] A way to split polygons?
Arnold Helmut Engelmann
ahe at dhi.us
Thu Mar 3 16:03:55 PST 2011
If you want to go the tiling route and want to try that: Create a layer of tiles (boxes) at the size you want. Then run the following query:
CREATE TABLE
tiled_geo_units as
SELECT
ST_Intersection(a.geometry, b.geometry) AS geometry,
a.*,
b.*
FROM
geo_units as a,
tiles as b
WHERE
ST_Intersects(a.geometry, b.geometry)
Where "geo_units" is the table with your geological units, and "tiles" is the table of boxes you created. This will intersect both layers and split the polygons at the tile boundaries. You can also add to the WHERE clause if you want to filter out just the "large" polygons, otherwise this will tile all your polygons. For this ST_NPoints will probably useful.
Arnold
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Peter N. Schweitzer
Sent: Thursday, March 03, 2011 13:21
To: pcreso at pcreso.com
Cc: PostGIS Users Discussion
Subject: Re: [postgis-users] A way to split polygons?
On 03/03/2011 04:00 PM, pcreso at pcreso.com wrote:
> It sounds like you are wanting to tile your polygons. Not really ideal, as each polygon is rendered via tiles, so you need to render them without borders to hide the tiles, then often plot the border as well, which still has all the vertices. Lots more work.
Hmmm. But in my KML, I'm not drawing the boundaries, so perhaps that disadvantage doesn't cause trouble in this situation?
> You might look at simplifying your polygons to reduce the number of vertices in each. If you manage your data topologically, this process will work better at retaining shared boundaries.
Mike Toews has suggested ST_Simplify or ST_SimplifyPreserveTopology, but I'm unsure of what value to use for the tolerance. The CRS is geographic, not projected.
> If you can use Google to provide vector zoom layers, then as you zoom
> in you can get less & less simplified versions... just like pyramid'ed
> rasters. Zoomed out you can't see so don't provide the unnecessary detail.
Use Google? I don't understand--is there some service they provide which might be used for data like these? Or are you referring to a way to describe the data in KML that I'm not familiar with? Either is plausible--I'm not being snarky here! I'm just writing KML with a PHP script that queries the PostgreSQL db, and have used these technologies in only simple ways so far. So when I say "Google" I mean only that the people who use these data typically open them with Google Earth, at least, those who experience this problem report it so.
Peter
Peter N. Schweitzer (MS 954, U.S. Geological Survey, Reston, VA 20192)
(703) 648-6533 FAX: (703) 648-6252 email: pschweitzer at usgs.gov <http://geology.usgs.gov/peter/> _______________________________________________
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
