[postgis-users] images in postgresql
pcreso at pcreso.com
Sun Mar 6 00:35:08 PST 2011
Hi Robert,
Can you do turbines as WFS with one of the fields the URL for the image, so the client has the image URL readily available? Or if you stick with WMS, you can still query the feature to get the URL of the image, see how to set up a query layer via your WMS server application.
Brent Wood
--- On Sun, 3/6/11, Robert Buckley <robertdbuckley at yahoo.com> wrote:
Subject: Re: [postgis-users] images in postgresql
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Sunday, March 6, 2011, 9:28 PM
thanks for the tip,
your book looks great...ill have to get it.
The windturbine table exists in EPSG:4326. I made a seperate table for the images because I didn´t wan´t to blow the size of the wind turbine table out of proportion and jeopardize performance.
I am making a simple application to show wind turbines as wms and I wanted to show the turbine in a popup. I´m not sure how to get the popup to display though.
Any examples?
Thanks,
Rob
Von: Paragon Corporation
<lr at pcorp.us>
An: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Gesendet: Samstag, den 5. März 2011, 18:21:49 Uhr
Betreff: Re: [postgis-users] images in postgresql
#yiv1693993084 DIV {
MARGIN:0px;}
Robert,
Is there a reason why you have the points in a separate table
or do you have points in both tables and you want to relate by a spatial
join?
If its a 1 to 1 relationship, we would just put them in
the same table.
As far as foreign keys go, you should have some identifier the
same in the two tables. Do you?
So it would be of the form
SELECT wt.wt_id, wt.geom, p.picture
FROM windturbines As wt INNER JOIN pictures As p ON wt.wt_id =
p.wt_id
or if they are spatially related by space
ST_DWithin(wt.geom, pt.geom, 10)
The 10 depends on the
spatial reference system or if you are using geography type then it means 10
meters. So I'm treating the wind turbine location and picture location as
the same if they are within 10 meters apart.
BTW: you might want to
read the first chapter of our upcoming book. It's a free download and
answers this type of question with concrete examples.
http://www.postgis.us/chapter_01
Leo
postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Robert Buckley
Sent: Saturday, March 05, 2011 5:39
AM
To: postgis-users at postgis.refractions.net
Subject:
I
am just experimenting at the moment with a project and could do with some
advice.
I have created a database which contains photos of
Windturbines. I also have a postgis database with the locations (points)
of the wind turbines and would like join the photos to the points via a link
table or foreign key.
As you can tell, I haven´t too much experience with
postgresql and relational database design. But i can imagine that the task
should not be too difficult.
I am just a bit unsure how to go about it.
The photos are on the linux server and the creation of the table and the insert
of the image was successfull. But how do i get the join and how would I
display this photo in a geoext project?
thanks for any
tips,
Robert
-----Inline Attachment Follows-----
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110306/cc3627e7/attachment.html>
